Cannot Install Components from Edit Mode
Following documentation, we have three red x's next to
Spellchecker, Microsoft Office Support                                    A component that enables the EPiServer CMS 5 Editor to use Microsoft Word spellchecker.                Component is not installed
                    Export to Excel, Microsoft Office Support                                    A component that can export forms data to Microsoft Excel.                Component is not installed
                    Advanced File Upload                                    A component that enables support for advanced file upload, for example drag-and-drop. Component is not installed
            You are using version N/A of EPiServer Client Components
When we press the install button, the pop up loads, but we just get a red x appear.
Any Ideas?
Marc.
#62945
Nov 05, 2012 17:31
I've had this issue too. I think my collegaue solved it by installing all three one after another.
#62948
Nov 05, 2012 19:46
Did you uncomment the Office Integration in web.config?
    Uncomment the following section replace UI in the path attribute with your customized UI path
    to enable Office integration in the application.
  <!--<location path="EPiServer/CMS/OfficeIntegration">
    <system.web>
      <authorization>
        <allow users="*" />
      </authorization>
    </system.web>
  </location>-->
#62969
Nov 06, 2012 10:16
Hello.
Yes, is uncommented out in the web.config, and amended the UI path to our own.
Been reading in blogs about manually extracting the dll's from the C:/Program Files... episerver etc etc, but no joy with that either.
Anyone know exactly what I have to type into the command prompt to get it to work?
Many Thanks.
#63058
Nov 08, 2012 11:25
