Can't access/find LiveMonitor after installation
Hi:
I just installed LiveMonitor on my EPiServer site. I followed all the steps found in the "Installation Instructions - Live Monitor" document. The only thing I did different was running the database script manually (epitraceHits.sql).
I can run my site as normal and login to EPiServer as always but the link on the menu on the CMS section does not appear. I tried also surfing to ../EPiTrace with no luck either.
I cannot see any errors or anything failing but I cannot seem to go in to Live Monitor.
Any ideas what was wrong or how can I troubleshoot this issue? Many thanks
#61893
Oct 05, 2012 10:08
Hi Carlos,
Do you have this binaries in your sites bin folder:
EPiServer.Trace.dll
EPiServer.Trace.CMS.dll
EPiServer.Trace.UI.dll
Also check if you have EPiTrace module registered in web.config /configuration/episerver.shell/protectedModules and virtual path provider with name EPiTrace
#61897
Oct 05, 2012 10:49
Hi Sergii
I was missing the virtual path provider. I took a look into the script that changes the code and added the missing line to my web.config. Still I cannot access Live Monitor. It does not appear in the CMS section and when I try to surf to ../EPiTrace. It says the link is wrong.
I wonder if in the virtual path I am pointing to the right physical path.
This is the one I have:
physicalPath="C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\application\UI\EPiServer\EPiTrace"
Thanks for the help
#61913
Oct 05, 2012 13:56
physical path should be C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiTrace\Application\EPiTrace
#61914
Oct 05, 2012 14:05
Thanks for the help, I can now access Live Monitor. I'm struggling now with another issue but I will do some research first otherwise I will come back to EPiServer World.
Cheers
#61919
Oct 05, 2012 14:49
