Is this a public domain or local? To be able to use Social Reach you need a public domain that the channel you're trying to add can reach (Twitter, Facebook, LinkedIn etc).
Hope this helps
Frederik
Its a local fictive domain (lives only in the host file). So it is the remote channel that fails?
Yes I would think so, since the oauth provider needs a public domain for its callback to succeed.
I have now tried to run the site on a public domain, but I still got the same error....
I noticed now that the error comes when I try to load any tab in Social Reach(shell). It is jquery/ajax that produce the error message.
Might be when trying to load all the existing channels (that you've added) - try reseting it by deleting the dynamic data store for Social Reach.
Oskar, did you find a solution to this problem? I have the same problem on my site.
Hi.
I hava a problem with the social reach plugin. When I try to add a channel i get the following error in the browser console:
Failed to load resource: the server responded with a status of 500 (Internal Server Error).
There is no Settings folder in the episerver.social folder. I have checked the content in the episervermoduel file, and can't find the settings folder. It is something wrong with the module, or is it something else?
