Simple address only works on default language
We have a site which utilizes globalization and have come across a problem where the simple address only works for the default language.
Our site is set to have the swedish as the default culture. We have a page published with a swedish and an english version with simple address page-swe and page-eng respectively. site.se/page-swe works as expected while site.se/page-eng responds with a 404. Both addresses work if I remove the default culture but.
Can anyone help me with this?
Regards Niklas
#62132
Oct 15, 2012 14:40
Hi Niklas!
For your information: We have done a fix in EPiServer 7 to fix this so if an upgrade is an option this might solve your issue as soon as we get EPiServer 7 out of the building.
Regards
Linus Ekström
#62138
Oct 15, 2012 15:35
Hi Linus,
I don't think that it is a big enough of an issue for us to warrant an upgrade at the moment but I will keep it in mind.
Thank you.
#62143
Oct 15, 2012 16:11
If the simple adresses are built up with suffixes that matches the lang code or atleast are consistent over the site so you could do some logica around it, I guess you could do a httpmodule that if i'ts a simple adress for example english you get the page for swedish, gets the linkurl and do a transferrequest with the whole url including correct language.
#62144
Oct 15, 2012 16:33
Hi, We have the same problem for one of our customers. Does anyone know how to or have already made a workaround for this?
#63024
Nov 07, 2012 13:01
