Two ways to override the path to the stylesheet either in episerver.config by setting the uiEditorCssPath attribute or by adding a dynamic property with the name UIEditorCssPaths with the path to the editor stylesheet. If you're still seeing the default stylesheets after that try doing an IISreset and closing/reopening your browser.
Hope this helps.
Frederik
Hi Marija!
Makes sure your css files follow the following guide:
http://world.episerver.com/Documentation/Items/Tech-Notes/EPiServer-CMS-6/EPiServer-CMS-6-R2/TinyMCE-Developers-Guide3/#EPiServerCSSAttributes
Hi, guys, thanks a lot for your time and effort!
@Frederik, these things were set.
@Toni, this helped, it's working now properly!!! I didn't think I had to set these, as my styles were visible in the dropdown.
I removed the css class property from TinyMCEPluginNonVisual, because it didn't work (only the episerver default classes were present in the dropdown) in TinyMCE editor.
Instead, I put it inside the episerver.config : uiEditorCssPaths="~/Styles/tinymce.css"
Now, they are added to the dropdown, but the default ones are still there.
Any recommendations on how to remove the EPiServer classes?
