Edit/Admin mode and the context menu not working with load balancing
I’ve deployed an EPiServer website to 2 web servers (load balance environment).
When using the LB IP I can authenticate my EPiServer user, but I can’t access edit or admin mode, it keeps on re-directing me back to the homepage.  Also, the context menu only works in IE.
 But, if I point directly to the one web server, all is fine.  I’ve thought it might be a sticky session issue and switched the one server off in the LB environment, but still have the same problem.
 The site URL in my episerver.config is set to the correct url and I’ve added it to the EPiServerFramework.config file
Many thanks
Danie
#52572
Aug 03, 2011 15:32
#52573
Aug 03, 2011 15:55
The context menu is failing because in FF and Chrome when referencing to /util/javascript/episerverscriptmanager.js it redirects to the homepage for some off reason
#52574
Aug 03, 2011 15:57
