Exception when save workflow.
I have this exception when save a workflow definition. I thought it was my DB but even after I restore my DB from a backup, the exception does not go away.
Can anyone please help.
To serialize an object the object has to have a schema (or inherits from IDictionary or IList) for type:System.Collections.Generic.List`1[[EPiServer.WorkflowFoundation.Workflows.ApproverItem, EPiServer.WorkflowFoundation, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7]], mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 for base type:EPiServer.WorkflowFoundation.CompiledWorkflowDefinition, EPiServer.WorkflowFoundation, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7
Best regards,
Nguyen
#52940
Aug 22, 2011 6:42
Do you have any custom workflow?
#52941
Aug 22, 2011 8:28
ApproverItem is used in the approval workflows. Make sure your episerver.config contains an entry for Approval Service as example below:
<episerver>
<workflowSettings>
<externalServices>
<externalService type="EPiServer.WorkflowFoundation.Workflows.ApprovalService,EPiServer.WorkflowFoundation"/>
</externalServices>
</workflowSettings>
#52942
Aug 22, 2011 10:23
I have the same error, tried to add the ReadyForTranslation workflow described in the admin manual(im using .net 4 not 2 described in the case above)
To serialize an object the object has to have a schema (or inherits from IDictionary or IList) for type:System.Collections.Generic.List`1[[EPiServer.WorkflowFoundation.Workflows.TranslationItem, EPiServer.WorkflowFoundation, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7]], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 for base type:EPiServer.WorkflowFoundation.CompiledWorkflowDefinition, EPiServer.WorkflowFoundation, Version=6.1.379.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7
Tried to add the service setting, didnt work
#54839
Nov 06, 2011 20:43
The externalService-seting solved the problem for us. Thank you!
#56326
Jan 17, 2012 20:47
