Page Not Found Error after upgrading from CMS 5 to EPiServer CMS 6 R2
After upgrading from EPiServer CMS 5 R2 to EPiServer CMS 6 R2 im getting the page cannot be found issue for some of the pages..
Below is my episerver.config settings for URL Rewriting..
<urlRewrite defaultProvider="URLRewriter">
    <providers>
      <add name="EPiServerFriendlyUrlRewriteProvider" type="EPiServer.Web.FriendlyUrlRewriteProvider,EPiServer" />
      <add enableSimpleAddress="true" friendlyUrlCacheAbsoluteExpiration="0:0:10" name="URLRewriter" type="EPiServer.Code.URLRewriter, EPiServer.Templates.Public" />
      <add description="EPiServer identity URL rewriter" name="EPiServerIdentityUrlRewriteProvider" type="EPiServer.Web.IdentityUrlRewriteProvider,EPiServer" />
      <add description="EPiServer bypass URL rewriter" name="EPiServerNullUrlRewriteProvider" type="EPiServer.Web.NullUrlRewriteProvider,EPiServer" />
    </providers>
  </urlRewrite>
Below is my URLRewriter.cs class file code:
using System;
using System.Collections.Specialized;
using EPiServer.Core;
using EPiServer.DataAbstraction;
using EPiServer.Globalization;
using System.Text;
using System.Text.RegularExpressions;
namespace EPiServer.Code
    public class URLRewriter : EPiServer.Web.FriendlyUrlRewriteProvider
        private static PageData _startPage = DataFactory.Instance.GetPage(PageReference.StartPage);
        private static PageReference _catalogueResultPageRef = new PageReference(Convert.ToInt32(_startPage["CatalogueResultPage"].ToString()));
        private static PageReference _productDataPageRef = new PageReference(Convert.ToInt32(_startPage["ProductDataPage"].ToString()));
        private string _catalogueResultPageNameInUrl, _catalogueResultPageTypeFileName, _catalogueResultUrlPrefix;
        private string _productDataPageNameInUrl, _productDataPageTypeFileName, _productDataUrlPrefix;
        public URLRewriter(): base()
            //Get the EPiServer page
            PageData catalogueResult = DataFactory.Instance.GetPage(_catalogueResultPageRef);
            PageData productData = DataFactory.Instance.GetPage(_productDataPageRef);
            //Get the URL segment of the page (the "Page name in address" property)
            _catalogueResultPageNameInUrl = catalogueResult.URLSegment;
            _productDataPageNameInUrl = productData.URLSegment;
            //Get the physical file name (the .aspx file)
            _catalogueResultPageTypeFileName = PageType.Load(catalogueResult.PageTypeID).FileName;
            _productDataPageTypeFileName = PageType.Load(productData.PageTypeID).FileName;
            //Get the URL prefix (for example "/Catalogue-Result/")
            _catalogueResultUrlPrefix = string.Concat("/", _catalogueResultPageNameInUrl, "/");
            _productDataUrlPrefix = string.Concat("/", _productDataPageNameInUrl, "/");
        protected override bool ConvertToExternalInternal(UrlBuilder url, object internalObject, Encoding toEncoding)
            //Check the internal URL to see if a user     //account page is being requested
            if (url.Path.ToLower().Contains(_catalogueResultPageTypeFileName.ToLower()) || _catalogueResultPageTypeFileName.ToLower().Contains(url.Path.ToLower()) && url.Path != string.Empty)
                //Create the custom friendly URL
                string friendlyPath = string.Empty;
                if (url.QueryCollection["epslanguage"] != null)
                    if (url.QueryCollection["epslanguage"].ToString() != string.Empty && url.QueryCollection["epslanguage"] != ContentLanguage.PreferredCulture.Name)
                        friendlyPath = string.Concat("/", url.QueryCollection["epslanguage"], "/", _catalogueResultPageNameInUrl, "/");
                    else
                        friendlyPath = string.Concat("/", LanguageBranch.Load(ContentLanguage.PreferredCulture).LanguageID, "/", _catalogueResultPageNameInUrl, "/");
                else
                string _keyword = string.Empty;
                //Get the keyword from the querystring
                if (url.QueryCollection["Tab"] != null)
                    _keyword = url.QueryCollection["Tab"];
                    if (_keyword != string.Empty && _keyword != null)
                        friendlyPath = string.Concat(friendlyPath, Url.Decode(_keyword));
                if (url.QueryCollection["search"] != null)
                    _keyword = url.QueryCollection["search"];
                        friendlyPath = string.Concat(friendlyPath, Url.Decode(_keyword).Replace(" ", "-"), "/");
                //Remove querystring parameters
                url.QueryCollection.Clear();
                //Set the URL to the new friendly URL
                url.Path = friendlyPath;
                //Indicate that the original URL has been rewritten
                return true;
            else if (url.Path.ToLower().Contains(_productDataPageTypeFileName.ToLower()))
                if (url.QueryCollection["partno"] != null)
                    string _keyword = url.QueryCollection["partno"];
                            friendlyPath = string.Concat("/", url.QueryCollection["epslanguage"], "/", _productDataPageNameInUrl, "/");
                        else
                            friendlyPath = string.Concat("/", LanguageBranch.Load(ContentLanguage.PreferredCulture).LanguageID, "/", _productDataPageNameInUrl, "/");
                    else
                    return true;
                else
                    //Use the default rewriting behavior
                    return base.ConvertToExternalInternal(url, internalObject, toEncoding);
            else //Not a user account details page
        protected override bool ConvertToInternalInternal(UrlBuilder url, ref object internalObject)
            if (url == null)
                return false;
            bool _bReplaceAP = false;
            //Check if the requested URL should be handled by the custom URL rewriting
            //if ((url.Path.StartsWith(_catalogueResultUrlPrefix, StringComparison.OrdinalIgnoreCase)))
            if (url.Path.ToLower().Contains(_catalogueResultUrlPrefix.ToLower()))
                NameValueCollection queryCollection = url.QueryCollection;
                //Get the language branch based on the requested URL
                string nonLocalizedPath;
                ContentLanguage.PreferredCulture = GetLanguageBranchAndPath(url.Path, out nonLocalizedPath).Culture;
                if (url.Path.ToUpper().Contains("/AP") && ContentLanguage.PreferredCulture.Name.Trim().ToUpper() == "EN-AU")
                    _bReplaceAP = true;
                //Set the internal object to a PageReference
                internalObject = _catalogueResultPageRef;
                //Ensure that the URL has a trailing slash
                if (!url.Path.EndsWith("/"))
                    url.Path = url.Path + "/";
                    //HttpContext.Current.Response.Redirect((string)url);
                string friendlyUrl = url.Path;
                //Get the internal URL
                string internalUrl = new Url(DataFactory.Instance.GetPage(_catalogueResultPageRef).StaticLinkURL).Path;
                //Set the URL to the internal URL
                url.Path = internalUrl;
                //Extract the URL segment of the partno
                string urlSegment = friendlyUrl.ToUpper().Replace(_catalogueResultUrlPrefix.ToUpper(), string.Empty);
                urlSegment = urlSegment.ToUpper().Replace("/" + ContentLanguage.PreferredCulture.Name.ToUpper(), string.Empty);
                urlSegment = urlSegment.ToUpper().Replace("/" + ContentLanguage.PreferredCulture.TwoLetterISOLanguageName.ToUpper(), string.Empty);
                if (_bReplaceAP)
                    urlSegment = urlSegment.ToUpper().Replace("/AP", string.Empty);
                //Remove trailing slash
                urlSegment = urlSegment.TrimStart('/');
                urlSegment = urlSegment.TrimEnd('/');
                //urlSegment = urlSegment.Length > 1? urlSegment.Substring(0, urlSegment.Length - 1) : (urlSegment.Length == 1? (urlSegment == "/"? string.Empty: urlSegment ): urlSegment);
                //Add the part no to the querystring
                //of the internal URL
                if (urlSegment != string.Empty)
                    if(urlSegment.Length == 1)
                        queryCollection.Add("Tab", Url.Decode(urlSegment).Replace(" ", "-"));
                    else
                        queryCollection.Add("search", Url.Decode(urlSegment).Replace(" ", "-"));
                //Add additional querystring parameters
                //to the internal URL
                //queryCollection.Add("epslanguage", ContentLanguage.PreferredCulture.TwoLetterISOLanguageName);
                queryCollection.Add("epslanguage", ContentLanguage.PreferredCulture.Name);
                queryCollection.Add("id", _catalogueResultPageRef.ID.ToString());
                //Indicate URL rewriting
                return true;
            //else if ((url.Path.StartsWith(_productDataUrlPrefix, StringComparison.OrdinalIgnoreCase)))
            else if (url.Path.ToLower().Contains(_productDataUrlPrefix.ToLower()))
                    _bReplaceAP = true;
                internalObject = _productDataPageRef;
                string internalUrl = new Url(DataFactory.Instance.GetPage(_productDataPageRef).StaticLinkURL).Path;
                string urlSegment = friendlyUrl.ToUpper().Replace(_productDataUrlPrefix.ToUpper(), string.Empty);
                if (_bReplaceAP)
                //urlSegment = urlSegment.Length > 1 ? urlSegment.Substring(0, urlSegment.Length - 1) : urlSegment;
                //urlSegment = urlSegment.Length > 1 ? urlSegment.Substring(0, urlSegment.Length - 1) : (urlSegment.Length == 1 ? (urlSegment == "/" ? string.Empty : urlSegment) : urlSegment);
                    queryCollection.Add("partno", Url.Decode(urlSegment).Replace(" ", "-"));
                queryCollection.Add("id", _productDataPageRef.ID.ToString());
                return true;
            else
                return base.ConvertToInternalInternal(url, ref internalObject);
        public override bool ConvertToInternal(UrlBuilder url, out object internalObject)
            internalObject = null;
            //Check if a user account details page is being requested
            //if ((url.Path.StartsWith(_catalogueResultUrlPrefix, StringComparison.OrdinalIgnoreCase)) || (url.Path.StartsWith(_productDataUrlPrefix, StringComparison.OrdinalIgnoreCase)))
            if ((url.Path.ToLower().Contains(_catalogueResultUrlPrefix.ToLower())) || (url.Path.ToLower().Contains(_productDataUrlPrefix.ToLower())))
                return true;
            else //Not a user account details page, use default rewriting
                return base.ConvertToInternal(url, out internalObject);
#52313
Jul 18, 2011 12:10
Hi Saran
You need to move your logic from the ConvertToInternalInternal method to TryConvertToInternal method.
Hope this helps
Frederik
#52325
Jul 18, 2011 21:23
Thanks a lot Frederik it worked well after converting my method ConvertToInternalInternal to  TryConvertToInternal method.But i got another issue my language selection dropdown list in the page was not working... Refer my another method above ConvertToExternalInternal any problem with that.? the requirement is if change the language in the dropdown list language the pagelanguage should change according to the language selected in the dropdownlist..Previously it also worked well with EPiServer CMS 5.
Thanks  a lot again!!!
#52401
Jul 21, 2011 16:14
The code below is just something I copied from the Demo tempaltes project:
<li runat="server" visible="false" class="iconLink languageLink">
		        <asp:HyperLink ID="Language" runat="server" Visible="false"></asp:HyperLink>
		        <asp:Label ID="LanguageListLabel" runat="server" AssociatedControlID="LanguageList" CssClass="hidden" Visible="false" text="Other languages" />
		        <asp:DropDownList runat="server" ID="LanguageList"  Visible="false" AutoPostBack="true" OnSelectedIndexChanged="ChangeLanguage">
		            <asp:ListItem Text="Other languages" Value="noLangSelected" />
		        </asp:DropDownList>
		        <noscript>
		            <asp:Button runat="server" ID="LanguageButton" OnClick="ChangeLanguage" Text="OK" Visible="false" />
		        </noscript>
</li>
/// <summary>
        /// Initializes the language link.
        /// Checks the number of available and enabled languages. If more than two,
        /// populates a dropdown-menu with the available and enabled languages.
        /// Otherwise sets the link to the not currently active language.
        /// </summary>
        private void SetLanguage()
            PageDataCollection languageBranches = DataFactory.Instance.GetLanguageBranches(CurrentPage.PageLink);
            //Filter so pages with Replacement language is filtered away.
            new FilterReplacementLanguage().Filter(languageBranches);
            if (languageBranches.Count > 2)
                LanguageList.Visible = LanguageListLabel.Visible = LanguageButton.Visible = LanguageList.Parent.Visible = true;
                foreach (PageData languageBranch in languageBranches.Where(p => p.LanguageID != CurrentPage.LanguageID && LanguageBranch.Load(p.LanguageID).Enabled))
                    LanguageList.Items.Add(new System.Web.UI.WebControls.ListItem(new CultureInfo(languageBranch.LanguageID).NativeName, languageBranch.LanguageID));
            else
                    Language.Visible = Language.Parent.Visible = true;
                    Language.NavigateUrl = EPiServer.UriSupport.AddLanguageSelection(languageBranch.LinkURL, languageBranch.LanguageID);
                    Language.Text = Translate(new CultureInfo(languageBranch.LanguageID).NativeName);
                    break;
        /// <summary>
        /// Redirects to the selected language.
        /// </summary>
        public void ChangeLanguage(object sender, EventArgs e)
            if (LanguageList.SelectedValue != "noLangSelected")
                Response.Redirect(EPiServer.UriSupport.AddLanguageSelection(CurrentPage.LinkURL, LanguageList.SelectedValue));
protected override void OnLoad(System.EventArgs e) { base.OnLoad(e); if (!IsPostBack) { if (Configuration.Settings.Instance.UIShowGlobalizationUserInterface) { SetLanguage(); } } }
Hope this helps.
Frederik
#52411
Edited, Jul 22, 2011 9:38
Hi Frederik,
Thanks a lot for the work and spending your valuable time for me. The language also working fine now. But Bcos of my mistake in the TryConvertToInternal() method. I didn't assign preferredCulture value and after assigning like below it works...
preferredCulture = GetLanguageBranchAndPath(url.Path, out nonLocalizedPath).Culture;
Thanks a lot.. and i have marked this post as answered....
#52414
Jul 22, 2011 12:33
