Custom URL Rewriting Functionality in EPiServer CMS 6 R2
Hi All,
   May i know how to get the friendly URL functionality using Custom URLRewriting in EPiServer CMS 6 R2.
Thanks in Advance..
#52314
Jul 18, 2011 12:26
Hi Saran
What do you want to achieve? Do you want to enable friendly URLs in EPiServer? Add your own logic?
URL rewriting in EPiServer is provider based so it is easy to replace it with your own logic. Take a look at episerver.config, you should see something like this:
<urlRewrite defaultProvider="EPiServerFriendlyUrlRewriteProvider">
    <providers>
      <add name="EPiServerFriendlyUrlRewriteProvider" description="EPiServer standard Friendly URL rewriter" type="EPiServer.Web.FriendlyUrlRewriteProvider,EPiServer" />
      <add name="EPiServerIdentityUrlRewriteProvider" description="EPiServer identity URL rewriter" type="EPiServer.Web.IdentityUrlRewriteProvider,EPiServer" />
      <add name="EPiServerNullUrlRewriteProvider" description="EPiServer bypass URL rewriter" type="EPiServer.Web.NullUrlRewriteProvider,EPiServer" />
    </providers>
  </urlRewrite>
Frederik
#52324
Jul 18, 2011 21:16
Hi Frederik,
Thanks for the reply.. i have already implemented the friendly URL Rewriting functionality for EPiServer CMS 5 R2 which worked well i have posted code samples in my previous posts..But after upgrading to EPiServer CMS 6 R2 the friendly URL Rewriting functionality was not working says page not found error.Any way i will try the code you provided and let you know again.
Thanks again..
#52339
Jul 19, 2011 9:04
Ah ok, see my answer in this thread: http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=52313&epslanguage=en
Frederik
#52340
Jul 19, 2011 9:15
