TinyMCE Upgrade Issue V6- V6R2
We are getting the following error for all our dynamic content settings components that contains the TinyMCE control.
Object reference not set to an instance of an object. -   System.Exception {System.NullReferenceException}
at EPiServer.Editor.TinyMCE.Editor.OnPreRender(EventArgs e)
   at System.Web.UI.Control.PreRenderRecursiveInternal()
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
This happened immediately after the upgrade from 6 to 6.2 of EPiServer.
Any ideas about how to resolve this would be much appreciated.
Regards,
Robert Gibbins.
#52047
Jul 04, 2011 14:59
Hi Robert!
I'm looking into a bug about the Tiny MCE web control throwing a null reference exception when used stand alone (that is: not a normal property in edit or on page edit mode). As far as I've seen, there was quite a rewrite of the set up for this control in order to handle the improved on page edit mode including support for Tiny MCE for CMS 6 R2. Unfortunately there does not seem to be a simple fix for this I we probably have to do some sort of rewrite of this. Perhaps you can use a client initiated Tiny MCE or a xhtml property until we do a fix?
#52071
Jul 05, 2011 9:26
Hi Linus,
Have you ever worked on Mobile Apps in EPIServer CMS 6? Bcoz i am not getting the right link to do that. Recently i found one MobilePack software......but it is giving so many errors......
#52271
Jul 14, 2011 7:47
Hi Robert!
I just ran into the same exception, after an upgrade, for the Tiny MCE control, did you find a solution?
/Kristoffer
#53173
Aug 30, 2011 16:22
There's a hotfix available from EPiServer support. Just contact them.
/Erik
#53197
Aug 31, 2011 14:28
Hi Erik,
IS there definitely a hotfix available? We contacted EPiServer but they have told us there is no fix available currently.
Al
#54795
Nov 03, 2011 11:56
YES there is.  It is the EPiServer.Data or EPiServer Assembly.  Pretty sure of it.  Tobias knows the exact assembly but I am almost certain it is EPiServer or EPiServer.Data you need to update.
I just confirmed that it is the EPiServer Assembly.  I ran into the same problem and uploaded the new EPiServer.dll to the gac on the server and WHALLA.  Works Like a charm
#54813
Edited, Nov 03, 2011 21:46
Does the new v501 patch version contain this fix? Applied to a machine and still getting the same problem.
#58276
Apr 17, 2012 11:03
Paul I think the 501 contains it. The latest general hotfix (502) has it at least.
Read more here:
http://world.episerver.com/Articles/Items/About-the-Latest-Updates-for-EPiServer-CMS-and-Relate/
#61197
Sep 11, 2012 15:07
