EPiServer CMS 6 R2 - 301 Redirects
Hello there,
I had posted this question in the CMS 5 forum (http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=46880&epslanguage=en). Re-posting it in CMS 6R2 now.
Is there a way to set 301 redirects in Episerver CMS 6R2?
The existing ones "Shortcut to a Link in EPiServer" & "Link to Page on another website" basically gives me a 200 (in Fiddler2) for the target url followed by a list of 304 for all static content served.
Thanks & regards,
Noel
#52347
Jul 19, 2011 14:18
Hello Noel
There is no built in way to handle 301's in EPiServer at the moment. If you know the URLs then the IIS Url rewrite module can handle this for you (if you are using IIS 7). I've previously blogged about using this module so you can use the same principle for explicitly redirect URLs:
http://www.david-tec.com/2011/04/Using-IIS7s-URL-Rewrite-feature-to-enable-good-SEO-practice-in-EPiServer/
David
#52348
Jul 19, 2011 14:36
Thanks for your response David.
I guess I will have to look at that then.
Thanks & regards,
Noel
#52350
Jul 19, 2011 15:46
Noel: You might want to take a look at the 404 module on EPiCode. I've blogged about it, see:
http://world.episerver.com/Blogs/Mari-Jorgensen/Dates/2011/6/A-Major-Facelift-for-the-404-Module/
#52431
Jul 25, 2011 14:39
Ah!! this sounds good.
Thanks Mari! Will have a look at this.
#52445
Jul 26, 2011 15:02
Hi, If I use David's method of using IIS and the Rewrite tool will this have any impact on the CMS, Images and any subdomains?
Many thanks
Jonathan
#71237
May 14, 2013 17:55
