Got this to work now... Googled a lot but nothing I found worked for me. I finally ended up adding handler mappings for .svc manually for my site. This can be done in IIS Manager. I copied the mappings from my "Default Web Site".
I have a similar problem.
The index is populated but no matter what I try searching for no results are returned. I'm using the FTS Facade by Paul Smith to populate the index and also to retrieve search results.
I hava also tried to retrieve the results directly from the FTS client like so:
FuzzyQuery query = new FuzzyQuery(searchTerm, Field.Default, (float)0.5);
return EPiServer.Search.SearchHandler.Instance.GetSearchResults(query, 0, 10);
But nothing seems to work.
Any input appreciated! :)
I found the problem. The page parameter is not zero based like the offset. Doh! It needs to be 1 or greater otherwise the service will be called with -10 for the offset which throws a 500 error.
Saw that the FTS from relate was released this friday so I decided to give it a try. I followed the instruktions in this blog post (http://world.episerver.com/Blogs/Paul-Smith/Dates1/2011/5/EPiServer-Full-Text-Search-Now-Available-For-CMS-6-R2/) but no index files are created. I can see that it pushes pages and files to the "tblBigTable" and http://mysite/IndexingService/IndexingService.svc is responding with "Endpoint not found". I'm I missing something here? Any ideas whould be appriciated... I'm running the site on Windows 7 x86 and .Net 4,0.
