Error when loading edit mode
I'm trying to load the edit page, but get an error message:
CS0117: 'EPiServer.Shell.Paths' does not contain a definition for 'ToShellClientResource'
Line 19:
Line 20: <!--[if gte IE 7]>
Line 21: <link type="text/css" href="<%= EPiServer.Shell.Paths.ToShellClientResource("ClientResources/Epi/Widgets/GlobalNavigation/GlobalNavigation_ie.css") %>" rel="Stylesheet" />
Line 22: <![endif]-->
Line 23: <!--[if lte IE 6]>
Source File: /UI/CMS/MasterPages/Frameworks/Framework.Master    Line: 21
#50937
May 17, 2011 16:55
Sounds like you have an older version of EPiServer.Shell loaded. Do you have an assembly redirect for it in web.config pointing it to the 6.2 version?
#50938
May 17, 2011 17:09
