SearchDataSource PageLink as PropertyParameter works but hardcoding PageLink attribute does not.
I hope someone can help really quickly with this one.
I have a simple search results page, copied from the AlloyTech Example Templates. Here is my Datasource control:
    <EPiServer:SearchDataSource ID="SearchDataSource" runat="server">
        <SelectParameters>
            <EPiServer:PropertyParameter Name="PageLink" PropertyName="SearchRoot" />
            <asp:controlparameter name="SearchQuery" controlid="SearchText" propertyname="Text"/>
            <asp:controlparameter name="OnlyWholeWords" controlid="SearchOnlyWholeWords" propertyname="Checked"/>
        </SelectParameters>
    </EPiServer:SearchDataSource>
I want to change this and hardcode the PageLink (so editors cant change it). From various pages on the web I see this syntax :
    <EPiServer:SearchDataSource ID="SearchDataSource" runat="server" PageLink='<%# EPiServer.Core.PageReference.StartPage %>'>
        <SelectParameters>
        </SelectParameters>
But when I use this syntax I always get no results. Please help! What am I doing wrong here?
#55817
Dec 19, 2011 16:41
Ammendum:
Theres definatly something funky going on with:
As literally hardcoding the Page ID into this property works!
PageLink='1'
This is all rather confusing, as <%# PageReference.StartPage.ID %> and <%# PageReference.StartPage.ToString() %>also don't work, but a hard coded ID is fine.
If anyone can help bring clarity that would be great, Ideally I'd like to be able to use something like this:
PageLink="<%# new PageReference(3) %>"
This strikes me as the proper way to pass a pagereference to the control by way of an ID, however hard coded ID without any binding control is ok for now.
#55818
Dec 19, 2011 16:53
You need to call DataBind() on your control from codebehind if you want to use databinding (<%#) syntax in the server attributes.
#55828
Dec 19, 2011 18:17
