Toggle rich/plain text
The TinyMCE Editor has a "Toggle rich/plain text" button which enables users to choose between rich or plain text paste. If you turn it on (for using plain text), it is automatically reset (to rich text) after a paste.
Is there anyway of configuring TinyMCE so that plain text paste is default?
#55173
Nov 21, 2011 12:19
Yes, I've seen that one, but I was hoping for an admin or config setting. Oh, well.... I guess I start writing the plugin then. :-)
#55208
Nov 22, 2011 16:18
Mari: Did you ever make that plugin? :) I tried using TinyMCENonVisualAttribute but a limitation in how EPiServer renders the code for tinymce.init() seems to limit what we're able to spit out to tinymce. can't have functions for example since EPiServer uses JSON to serialize the data and JSON doesn't like functions.
#61742
Edited, Oct 01, 2012 8:29
Sorry, never got around to it.
#61760
Oct 01, 2012 15:07
