Does it work under HTTPS and without load balancing?
Also try to open the URL of Live Monitor trace service to see the error details. Trace service endpoint should be configured in your web.config for EPiServer.Trace.Services.ITraceService contract.
We're running CMS 6 R2 in a load balanced environment. We are also rewriting all /secure/ URLs to HTTPS. We've installed Live Monitor as per the instructions and also set the appropriate HTTPS settings. This does not work, it returns the error:
"Failed to load root node".
If we remove the HTTPS rewrites and serve it under HTTP it works fine.
Has anyone managed to get Live Monitor working under HTTPS?
Cheers
Tim
