Jquery Ajax Call
Hi ,
Am working on a new project and trying to implement the Jquery ajax call. Here the problem is i have implemented the pagetype and created the page using it. and in my template page i have created the  WEB METHOD for my ajax call
in my template file wich is default.aspx , ihave method
 [WebMethod]
        public static string Add()
            return "2";
and am trying to access this methid using Jquery ajax method as
 $.ajax({
        type: "POST",
        url: "/Prototype/template/page/default.aspx/Add",
        data: "{}",
        contentType: "application/json; charset=utf-8",
        dataType: "json",
        success: function (msg) {
            alert(msg.d);
But am not abel to get the values from this methos . What am i doing wrong ..?
#54432
Oct 14, 2011 13:59
This isn't really anything to do with EPiServer CMS. I recommend you post this question on StackOverflow or some other more generic forum
#54435
Oct 14, 2011 15:18
This is really a very generic question and not particulary related to EPiServer, but what you can do is to add following Http module:
<add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
To <system.web> or <system.webServer> element (depending on pipeline mode - classic or integrated).
This is a common pitfall when creating new project and 1st thing to try out is Ajax support for Asp.Net application.
#54708
Oct 29, 2011 17:05
Hello,
Was this problem solve? I have the same issue here. I have a "POST" ajax call from my Template page and it return with Status Code: 404! I can't find wrong to my code, my WebMethod is there.
And I have already the line below to my web.config file.
Please help me.
#60497
Edited, Aug 13, 2012 11:38
Add the Attribute
[System.Web.Script.Services.ScriptService] to The WebService Class.
#60623
Aug 17, 2012 15:23
