And in the toolbar, meybe there should be a divider between the Cancel button and Mark as in use button?
+1 for the task list....
Is there an option to set "Release In Use" when you publish the page?
This is a tricky one however, as there are a lot of editors who publish a page just to see the result and then go back to editing the page. Maybe a dialog that you can switch on / off?
Should there be a timestamp on the icon in the tree structure? Now it shows which user has marked the page as in use. Is there a schedule job that clean up old "marked as in use" pages (as it is with Autosaved Drafts)?
Good idea about the task list.
As Stein-Viggo said different editors would want different things regarding autmatically releasing the marked as in use. We decided to do it one way, but I agree that a configuration would be nice.
No, there is no job to clean pages marked as in use. Although it wouldn't be that hard to build one.
Can't promise any changes to release, but the feedback is appreciated.
Regards
Per Gunsarfs
EPiServer Development Team
Pages marked as in used by me should be added to the task list so you can find them again.
