User control created is not running.
I have started to build a user control like this way.
Schedule.ascx file code
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
namespace Tree.Templates.DynamicContent.Vpo
    public partial class Schedule : System.Web.UI.UserControl
        protected void Page_Load(object sender, EventArgs e)
Schedule.ascx
<%@ Control Language="C#" AutoEventWireup="true" CodeFile="Schedule.ascx.cs" Inherits="Tree.Templates.DynamicContent.Vpo.Schedule" %>
And the code for rendering control like this
using System;
using System.Linq;
using System.Web;
using EPiServer;
using EPiServer.Core;
using EPiServer.DataAbstraction;
using EPiServer.DynamicContent;
using EPiServer.PlugIn;
using Tree.Templates.DynamicContent.Vpo;
    [GuiPlugIn(
        Url = "~/Templates/DynamicContent/Schedule.ascx",
        Area = PlugInArea.DynamicContent
    public class ScheduleList : IDynamicContent
        public static int instanceId = 0;
        public System.Web.UI.Control GetControl(EPiServer.PageBase hostPage)
            /*Resets if reachec 10 to 0*/
            if (instanceId == 100)
                instanceId = 0;
            var userControl = hostPage.LoadControl("~/Templates/DynamicContent/Schedule.ascx");
            return userControl;
        public EPiServer.Core.PropertyDataCollection Properties
            get { throw new NotImplementedException(); }
        public string Render(EPiServer.PageBase hostPage)
        public bool RendersWithControl
            get { return true; }
        public string State
            get;
            set;
and in the EPIServer.config section write dynamic config like this
dynamicContent>
    <controls>
      <add description="Displays a property from any page" name="PagePropertyPlugin" type="EPiServer.DynamicContent.PlugIn.DynamicPageProperty, EPiServer" />
      <add description="Schedule" name="Schedule" type="Tree.Templates.DynamicContent.Vpo.ScheduleList" />
    </controls>
  </dynamicContent>
but when i am runnig project it is giving error
The Dynamic Content control type Schedule could not be loaded. Check the <dynamicContent> section in web.config
What is the problem
#82840
Mar 20, 2014 11:22
Did you get this to work yet? I can't really see much odd with your setup, but here is a shot. See if you can add your assembly name to the type attribute in your configuration. That would be something like:
<add description="Schedule" name="Schedule" type="Tree.Templates.DynamicContent.Vpo.ScheduleList, Tree" />
If your binary was called Tree.dll
EPiServer's DynamicPageProperty is in EPiServer.dll
like so.
Hope it helps.
//Mathias
EDIT: Removed failed config paste.
#82954
Edited, Mar 22, 2014 0:26
