How to get content of single page by Webservices?
I am new to Episerver and have basic question, I search quite long time and didn't found the answer: Is there a way to get all content of single page by webservices?
I use DataFactoryService GetPage to get page details and GetChildren to get subpages. What should I use to get content of single page?
#80980
Feb 06, 2014 12:09
Hi Michal!
What are you meaning with "get content of a single page"? Are you referring to content that is used by the page, like images etc?
#80982
Feb 06, 2014 13:15
Hi Linus,
Yes, I mean all content that exists on single page like texts, images etc.
#81005
Feb 07, 2014 8:00
Hello Michal!
Is it the rendered page (the content as markup) you are after? If so, I did a bit of work in that direction once and can get you the code if you'd like; otherwise I would also have to ask you to elaborate a bit :)
Cheers, Mathias
Edit: Meh, too slow >_<
#81006
Edited, Feb 07, 2014 8:04
You have a few examples on how to access the values of a page's properties here, if you are using PageTypeBuilder you can get the content by for instance CurrentPage.MainBody; see Joels article.
//Mathias
#81007
Feb 07, 2014 8:15
But is there a way to obtain this data using default Webservices?
#81013
Feb 07, 2014 9:41
Check out PageStoreService and see if it does what you want. I believe the default path is /WebServices/PageStoreService.asmx. It has a GetPage operation that reads a single page. You will then get the information as an XML response. I haven't used it myself but that's the best answer I can give you. Hope it helps!
//Mathias
#81080
Feb 10, 2014 8:06
