There's a URL rewriter module that rewrites the modules before delivering the document to the HTML browser. It should not matter what browser you use, the FURL rewriting should either be on or off for all browsers. If it's not a caching issue.
Yes, as I said to the customer. They used MakingWaves URLRewritter before with the same problem, but is now on the good old EPiServerFriendlyUrlRewriteProvider.
I can open friendlyURL with Opera, but all links from that page points to a unfriendly URL. For me this makes no sense, how can this be problem with the cache if it is a problem on both production and test?
I agree with Toni. Since rewriting urls is done on server side it should not matter which browser you use for FriendlyUrl. Test again and make sure the browser cache is empty so that your Opera browser hasn't cached an old page when you had it turned off.
This is not likely the case, but anyway.....
The URL filter is only attached to the request if the Response.ContentType is text/html. Could you verify by e.g. fiddler or a browser addon tool that the ContentType is text/html.
Yeah, it is RESPONSE BYTES (by Content-Type)
application/xhtml+xml
not text/html, and cache-cleared did not help.
Hmm, according to this http://my.opera.com/karlcow/blog/2011/03/03/wrong-to-be-right-with-xhtml it seems IIS sends different ContentType to Opera.
A workaround for you could perhaps be to write an initialization module that hooks up to an event raised before the url rewrite filter is attached and in there ensures ContentType is text/html if the handler is System.Web.UI.Page. Something like:
[InitializableModule]
public class ContentTypeModule : IInitializableModule
public void Initialize(Framework.Initialization.InitializationEngine context)
UrlRewriteModuleBase.HttpRewriteInit += delegate(object sender, UrlRewriteEventArgs args)
(sender as UrlRewriteModuleBase).HtmlAddingRewriteToExternalFilter += delegate(object s, UrlRewriteEventArgs e)
if (HttpContext.Current.Handler is System.Web.UI.Page)
HttpContext.Current.Response.ContentType = "text/html";
public void Uninitialize(Framework.Initialization.InitializationEngine context)
I have a problem with Opera and friendly URLs
A link may look like this in all other browsers: http://test.no/no/Nyheter/
and Opera shows this: http://test.no/Templates/Test/SearchAndFilter.aspx?id=396&epslanguage=no
Has anybody else had this problem? I dont have this error on other CMS6 projects, and can`t really find any solutions.
