Page disappears temporarily when using episerver delayed publishing feature
When using Episerver delayed feature the page gets published  but disappears from the website for some time.
If it was our front page as an example, I  would be without a website for 15-30 seconds. Is this expected behaviour or what?
#79072
Dec 09, 2013 10:48
I have noticed earlier that episerver does not reset page outputcache when a page is published by the built in functionality as for instance delayed published.
Do you have page outputcache tured on? Could you try to turn it off and check if the problem still exists?
#79143
Dec 10, 2013 11:06
Hi Andreas where could I check about pageoutputcache feature ?
#79381
Dec 16, 2013 11:02
In episerver.config, <siteSettings>-node there is a setting called httpCacheExpiration. Try setting this to 00:00:00.
#79382
Dec 16, 2013 11:07
it is set to 00:00:00 and pageCacheSlidingExpiration is also set to 00:00:00.
#79387
Dec 16, 2013 11:59
