Mirroring issue with short URLs
Frequently when we mirror, short URLs for some pages stop working. We then have to mark the affected pages as changed and re-mirror them to get them working again. This is quite a bad fault as it stops some important pages from working. Is this a known fault?
Regards,
John
#60508
Aug 13, 2012 14:33
P-O
Did this ever get resolved? Did anyone else have this problem and solved it?
We are experiencing the same issue in a environment with EPiServer 6R2 where mirroring is set up with EPiServer 5 mirroring.
Sometimes when new version of a page is published the short adress is not copied when the mirroring job runs. Republishing the source page seems to solves this, but that really is no solution since that can cause broken links. Does anyone know why the short adresses gets missing in the mirroring sometimes?
Best Regards
Per-Olof
#141388
Nov 13, 2015 15:09
