This can happen when the user running the app pool does not have modify access to your episerver.framework.config file. Try giving this user (probably Network uUser or IUSR) modify access to both episerver.framework (and web.config). And run your application again. Alternativliy you can modify your episerver.framework.config file manually: Add correct mappings inside the sections siteHosts and automaticSiteMapping, corresponding for your site instance in IIS.
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.Stack Trace:
Version Information: Microsoft .NET Framework Version:2.0.50727.5456; ASP.NET Version:2.0.50727.5456
EPiServer.Global.UrlRewriteProvider.ConvertedToInternal += parliamentaryRewriteUrl;
