Episerver 6 R2 NLB Issue
I am facing a problem in Episerver 6 R2. I have my website on NLB server. When I am trying to create a new page in episerver then that page is visible when i browse my website from one server out of two on NLB but these changes are not visible at all the time when I browse my site from other server. When I refresh my page from this server sometimes changes are reflected and sometime they are not.
Kindly help me with any solution. Any help would be highly appreciated.
#57471
Mar 15, 2012 14:41
In EPiServer.config... Do you have the same siteId for both web servers? Do you have enableRemoteEvents set to true?
#57694
Mar 24, 2012 0:27
Yes Johan,,,,,enableremoteevents set to true n same site ID
#57698
Mar 24, 2012 10:41
Then you probably have a network issue concerning UDP. Take a look at the documentation events system troubeshooting and also this blog post:
http://blog.fredrikhaglund.se/blog/2009/09/22/episerver-cms-how-to-configure-remote-events-with-many-servers-and-firewalls-between-them/
Also try and use EPiServerRemoteEventsListener or a regular UDP sniffing tool and see if the server is receiving calls from the other server.
#57699
Edited, Mar 24, 2012 12:06
EPiServerRemoteEventsListener  is used and pblm is solved now ...thanx for concern :)
#57700
Mar 24, 2012 12:24
