given assembly name or codebase was invalid
After upgrading to CMS 6.0 from CMS 5.2 i am getting this errormessage:
The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)
Exception Details: System.IO.FileLoadException: The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)
Source Error:
Stack Trace:
[FileLoadException: The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)]
   System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMarkHandle stackMark, Boolean loadTypeFromPartialName, ObjectHandleOnStack type) +0
   System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark, Boolean loadTypeFromPartialName) +314
   System.Type.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +95
   System.Web.Compilation.BuildManager.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +124
   System.Web.Handlers.AssemblyResourceLoader.EnsureHandlerExistenceChecked() +11461706
   System.Web.Handlers.AssemblyResourceLoader.IsValidWebResourceRequest(HttpContext context) +16
   System.Web.Security.FormsAuthenticationModule.OnEnter(Object source, EventArgs eventArgs) +200
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +80
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +270
#64343
Dec 18, 2012 11:37
