You have the FooterTemplate but I guess this is not what you're after.
I have in some cases fetched the pagedatacollection myself and added metatada style properties programmatically to the pagedata objects before databinding.
Then I could use the metadata properties to decide wich styles to use.
Here's a nice post from Fredrik Vig about the PageList: http://www.frederikvig.com/2009/07/episerver-web-controls-pagelist/. It also links to some posts from Erik Nordin about extending the episerver pagelist.
Hi, I am using EpiServer PageList control. I am trying to figure out last item in the control so that I would like to set different CSS. It doesn't have <Seperator Template> like in Repeater control. Any help is appreciated ! thanks.
