Object reference not set to an instance of an object - on site startup
Hi, I'm a newbie to EpiServer, trying to setup my first site through deployment center. Site is crashing after installation.
I found stack trace like this. Any help would be appreciated.
   EPiServer.Configuration.Settings.get_Instance() +49
   EPiServer.UriSupport.get_InternalUIUrl() +74
   EPiServer.SiteBase.OnValidateRequestAccess(ValidateRequestAccessEventArgs e) +141
   EPiServer.Global.Global_PreRequestHandlerExecute(Object sender, EventArgs e) +131
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69
#61989
Oct 09, 2012 14:07
Hi Suresh,
Could you look in your episerver.config and see if there is a site element?
<episerver>
  <sites>
    <site siteId="MySite" description="Short description of the site">
#61994
Oct 09, 2012 15:15
Yes, there is a site element. I had a look into SiteSettings element and UiUrl attribute.
#61995
Oct 09, 2012 15:25
