VPP 404 issue
I am having a strange issue with VPP folders returning 404 errors.
I have a Virtual Path Native Provider mapped to a server drive.
Files can be uploaded in edit mode correctly.
however, when I try and view them in a browser, I am unable to load anything but image (png) files.
.txt, and .pdf files return 404, even though they exist in the directory.
Any ideas please?
#50577
May 04, 2011 16:50
You need to add the path in web.config Also. Like global and documents
#50579
May 04, 2011 17:46
Global and Documetns don't have paths in web.config, apart from the <add path.... part, which is present in the one that is causing the issues:
The paths are mapped in episerver.config
  <location path="Documents" inheritInChildApplications="false">
    <system.web>
      <!-- Setup the StaticFileHandler for the wildcard mapping to work in IIS6 -->
      <httpHandlers>
        <add path="WebResource.axd" verb="GET" type="System.Web.Handlers.AssemblyResourceLoader" validate="true" />
        <add path="*" verb="*" type="EPiServer.Web.StaticFileHandler, EPiServer" validate="true" />
      </httpHandlers>
    </system.web>
    <staticFile expirationTime="-1.0:0:0" />
  </location>
  <location path="Global" inheritInChildApplications="false">
    <system.web>
      <httpHandlers>
      </httpHandlers>
    </system.web>
  </location>
       <location path="Otherfiles">
    <system.webServer>
      <handlers>
        <add name="webresources" path="WebResource.axd" verb="GET" type="System.Web.Handlers.AssemblyResourceLoader" />
        <add name="wildcard" path="*" verb="*" type="EPiServer.Web.StaticFileHandler, EPiServer" />
      </handlers>
    </system.webServer>
  </location>
#50580
Edited, May 04, 2011 17:57
Is the site running on IIS6 or IIS7?
If you look in your config above you can see that Documents and Global are configured with IIS6 syntax (<system.web><httpHandlers>) while OtherFiles is configured with IIS7 syntax (<system.webServer><handlers>). Try to change the settings for OtherFiles to use IIS6 syntax.
#50596
May 05, 2011 7:46
Thanks Johan,
I was using IIS6, and changing that solved my issue.
#50598
May 05, 2011 8:57
