You can change this behaivor by attaching your self to this event
UrlSegment.CreatingUrlSegment += new EventHandler<UrlSegmentEventArgs>(UrlSegment_CreatingUrlSegment);
Then you can change the replace string, or as this example translate to english when characters in the url segment is only -
static void UrlSegment_CreatingUrlSegment(object sender, UrlSegmentEventArgs e)
string uRLSegment = e.PageData.URLSegment;
if (string.IsNullOrEmpty(uRLSegment))
uRLSegment = e.PageData.PageName;
if (uRLSegment == null)
uRLSegment = "";
string urlFriendlySegment = ReplaceIllegalChars(uRLSegment);
if (string.IsNullOrEmpty(urlFriendlySegment) || urlFriendlySegment.Replace("-","")=="")
urlFriendlySegment=TranslateUsingGoogle(e.PageData.PageName, e.PageData.LanguageID, "en");
e.PageData.URLSegment = urlFriendlySegment;
internal static string ReplaceIllegalChars(string inputString)
string InvalidSegmentNames = @"%|^COM[0-9]([/\.]|$)|^LPT[0-9]([/\.]|$)|^PRN([/\.]|$)|^CLOCK\$([/\.]|$)|^AUX([/\.]|$)|^NUL([/\.]|$)|^CON([/\.]|$)";
Regex regexValidUrlChars = new Regex(@"^[A-Za-z0-9\-_~]+$", RegexOptions.Compiled);
Regex regexFindInvalidUrlChars = new Regex(@"[^A-Za-z0-9\-_~]{1}", RegexOptions.Compiled);
Regex regexInvalidSegmentNames = new Regex(InvalidSegmentNames, RegexOptions.Compiled | RegexOptions.IgnoreCase);
StringBuilder builder = new StringBuilder(inputString);
MatchCollection matchs = regexFindInvalidUrlChars.Matches(inputString);
for (int i = 0; i < matchs.Count; i++)
object obj2 = UrlSegment.GetURLCharacterMap()[builder[matchs[i].Index]];
if (obj2 != null)
builder[matchs[i].Index] = (char)obj2;
else
builder[matchs[i].Index] = '?';
builder.Replace("?", "");
return builder.ToString();
public static string TranslateUsingGoogle(string text, string fromLang, string toLang)
if (fromLang == null)
fromLang = "auto";
if (toLang == null)
toLang = "en";
string address = string.Format("http://www.google.com/translate_t?hl=en&ie=UTF8&text={0}&langpair={1}", text, fromLang + "|" + toLang);
string str7 = new WebClient().DownloadString(address);
str7 = str7.Substring(str7.IndexOf("id=result_box"), 500);
str7 = str7.Substring(str7.IndexOf(">"));
str7 = str7.Substring(0, str7.IndexOf("</div"));
Regex removeSpan=new Regex("<[^>]*>");
str7=removeSpan.Replace(str7,"");
return str7;
Thanks for the reply, but it doesn’t recognise the characters that are causing my issues, to replaces them with nothing, as in the build in functionality.
Is it possible to add items to the GetURLCharacterMap() collection?
you have to make your own CreatingUrlSegment, and for instance replace ě" and the "č to e and c before you call the base method
Accented chars in URLS not being replaced
We have found an issue where certain characters that should form part of the URL.
For example, we have the following page title that also forms the URL: (this is Czech)
Náměty pro cvičení
Episerver correctly replaces the "á" with a standard "a".
However, the "ě" and the "č" are just being removed from the URL.
The URL is therefore: /Namty-pro-cvieni/ when it should be /namety-pro-cviceni/
Is there a "mapping" file somewhere which allows you specify replacements characters?
