Active Directory configuration
I'm currently trying to configure ActiveDiretory integration on a intranet site for a customer.
I've used Softterra LDAP Administrator to verify the connection to AD, however I have some
problems making the intranet work with AD.
To make Softterra work I needed to use GSS Negotiate mechanism, not simple.
Do Episerver have any requirements on what type of mechanism that shall be used??
The errormessage I get is:
Logon failure: unknown user name or bad password
The exception occurs in Web.config on "type="Episerver.Security.ActiveDirectoryRoleProvider, Episerver"
Anyone have experience with troubleshooting AD connection??
#55878
Dec 21, 2011 14:03
Added domain on the user.
This resulted in another exception.
Episerver.Core.AccessDeniedException: Access.denied
#55879
Dec 21, 2011 14:10
Remember to add the AD role to the location elements in web.config to give the user access to edit/admin/dashboard. Like the exceptions says, the user doesn´t have access.
Hope this helps.
Frederik
#55890
Dec 21, 2011 20:52
Hi Jon Haakon,
take a look at this blog post: http://fredrikvonwerder.blogspot.com/2011_09_01_archive.html
Also, if you are having problems with Softerra LDAP Explorer, try the AD Explorer tool by MS: http://technet.microsoft.com/en-us/sysinternals/bb963907  I've used this to successfully test AD connections in EPiServer in previous projects.
#56967
Feb 17, 2012 21:37
