"Timeout expired" error when loading site or cms
I am receiving a timeout error when loading either the site or the CMS on my local PC. This project has been running fine for nearly a year and is still running fine on other developers' machines.
Any ideas?
More info:
[SqlException (0x80131904): Timeout expired.  The timeout period elapsed prior to completion of the operation or the server is not responding.]
   EPiServer.DataAccess.DataAccessBase.GenerateMasterCode() +759
   EPiServer.DataAccess.DataAccessBase.MasterSlaveHandling() +386
   EPiServer.DataAccess.<>c__DisplayClass1`1.<Execute>b__0() +39
   EPiServer.DataAccess.DatabaseFactory.Execute(Action`1 method) +427
   EPiServer.DataAccess.DataAccessBase.Execute(Action`1 action) +284
   EPiServer.DataAbstraction.UnifiedPathInfo.LoadFromVirtualPath(String virtualPath) +101
   EPiServer.DataAbstraction.UnifiedPathInfo.Load(String path) +94
   EPiServer.FileSystem.DefaultAccessControlList..ctor(String path) +121
   EPiServer.Web.Hosting.DirectoryAccessControl..ctor(String virtualPath) +42
   EPiServer.Web.Hosting.UnifiedDirectory.get_DirectoryAC() +332
   EPiServer.Web.Hosting.UnifiedDirectory.QueryAccess() +123
   EPiServer.Web.Hosting.UnifiedDirectory.QueryDistinctAccess(AccessLevel access) +26
   EPiServer.Web.Hosting.VirtualPathVersioningProvider.GetDirectory(String virtualPath) +448
   EPiServer.Web.Hosting.VirtualPathHandler.InitializeProviders(ProviderSettingsCollection providers, Boolean captureCustomExceptions) +1718
   EPiServer.Web.InitializationModule.InitializeVirtualPathProviders(VirtualPathElement vpElement) +127
   EPiServer.Web.InitializeEngine.Initialize() +663
   EPiServer.Web.InitializationModule.Initialize(EPiServerSection config, Settings settings, ConnectionStringSettingsCollection connectionStringSettings) +2208
   EPiServer.Web.InitializationModule.<StaticInitialization>b__4() +41
   EPiServer.Web.InitializationModule.StaticInitialization() +1904
   EPiServer.Web.InitializationModule.Initialize(InitializationEngine context) +49
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +853
   EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType) +115
   EPiServer.Framework.Initialization.InitializationModule.StaticInitialization(HostType hostType) +227
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +53
   EPiServer.Global..ctor() +76
   PROJECTNAME.WebUI.Global..ctor() +41
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\root\abca76d9\23ea2578\App_global.asax.v76my8oj.0.cs:0
#54380
Oct 12, 2011 16:46
SQL Server is running fine. I can query tables in the db and I ran SQL Profile while trying to load the site and saw nothing obviously wrong.
#54381
Oct 12, 2011 16:51
Any Firewall/Antivirus software installed recently? Or that might be blocking access to the DB.
#54384
Oct 12, 2011 17:56
No firewall/antivirus installed recently.
In the end I took the db offline then brought it back online and it fixed the problem.
#54412
Oct 13, 2011 11:05
