Forms problem, white / crash!!
Hi, using IE9 or Chrome (latest) any form eventuelly crashes just doing regular input and adding columns etc. Looks like all the html is pushed away or a javascript error of some sort (no error in browser). When this happens, I cannot save the form. Everything is lost! Much irritating and must be fixed!
Anyone know what's going on? Does EPI6 still require our users to use a specific version of Windows and web browser? This was the reason we switched from EPI4, to get rid of the requirement of having certain versions of win / browser.
Please respond ASAP. Thank you
#54345
Oct 11, 2011 9:13
No you should be able to use both IE9 and Chrome (and Firefox and Opera and Safari).
Try to catch the error (via debug logging or with a Javascript debugger) and see if you work out what is causing it.
Otherwise you or your partner can always ask EPiServer Support.
#54346
Oct 11, 2011 9:59
