Status on spell checker for Tinymce?
I need to install a spell checker for a customer on tinymce.
I found and implemented the page:
http://world.episerver.com/Blogs/Ben-Edwards/Dates/2010/4/EPiServer-6--Its-2010-and-we-can-check-our-spelling-with-a-bit-of-configuration/
The problem is that I can't find a button for spell checking on the editor.
The plug-in manager in admin mode shows Epi.Framework.common.
I have looked on "Custom settings" on the property on the page type, but couldn't see anything that looked like
a spell checker button.
Anybody that have implemented the spell checker for tinymce with success!?
In advance thanks for your help!
Kind regards,
Jon Haakon
#46901
Jan 10, 2011 15:35
When tracing the log I find:
2011-01-11 14:01:55,190 DEBUG [7] EPiServer.Web.UrlRewriteModule.HttpUrlRewriteToInternal -
Url is not valid for rewrite. Returning URL http://inter.royken.prod/util/Editor/TinyMCEi18n.aspx?language=en&path=/tinymce&recursive=true
The url shown above is:
tinyMCE.addI18n({en:{advanced:{separator_desc:"Separator",address:"Address",anchor_delta_height:"",
anchor_delta_width:"",anchor_desc:"Insert/Edit Anchor",backcolor_desc:"Select Background Color",
backcolorpicker_desc:"Select Background Color",block:"Format",blockquote:"Blockquote",blockquote_desc:"Blockquote"
,bold_desc:"Bold (Ctrl+B)",bullist_desc:"Unordered List",charmap_delta_height:"",
charmap_delta_width:"",charmap_desc:"Insert Custom Character",cleanup_desc:"Cleanup Messy Code",
clipboard_msg:"Copy/Cut/Paste is not available in Mozilla and Firefox.\nDo you want more information about this issue?",
code:"Code",code_desc:"Edit HTML Source",colorpicker_delta_height:"",colorpicker_delta_width:"",copy_desc:"Copy",
custom1_desc:"Your custom description here",cut_desc:"Cut",dd:"Definition description",div:"Div",dt:"Definition term ",
font_size:"Font size",fontdefault:"Font family",fontselect_desc:"Font family",fontsizeselect_desc:"Font size",
forecolor_desc:"Select Text Color",forecolorpicker_desc:"Select Text Color",formatselect_desc:"Format",
h1:"Heading 1",h2:"Heading 2",h3:"Heading 3",h4:"Heading 4",h5:"Heading 5",h6:"Heading 6",help_desc:"Help",
hr_desc:"Insert Horizontal Rule",image_delta_height:"",image_delta_width:"",
image_desc:"Insert/Edit Image",image_props_desc:"Image properties",indent_desc:"Indent",italic_desc:"Italic (Ctrl+I)",
justifycenter_desc:"Align Center",justifyfull_desc:"Align Full",justifyleft_desc:"Align Left",justifyright_desc:"Align Right",
link_delta_height:"",link_delta_width:"",link_desc:"Insert/Edit Link",more_colors:"More colors",
newdocument:"Are you sure you want clear all contents?",newdocument_desc:"New document",
numlist_desc:"Ordered List",outdent_desc:"Outdent",paragraph:"Paragraph",
paste_desc:"Paste",path:"Path",pre:"Preformatted",redo_desc:"Redo (Ctrl+Y)",
removeformat_desc:"Remove Formatting",samp:"Code sample",strikethrough_desc:"Strikethrough",
striketrough_desc:"Strikethrough",style_select:"Styles",styleselect_desc:"Styles",sub_desc:"Subscript",sup_desc:"Superscript",
toolbar_focus:"Jump to tool buttons - Alt+Q, Jump to editor - Alt-Z, Jump to element path - Alt-X",underline_desc:"Underline (Ctrl+U)",
undo_desc:"Undo (Ctrl+Z)",unlink_desc:"Unlink",visualaid_desc:"Toggle Guidelines/Invisible Elements"},
advimage:{advimage_desc:"Change image dialog to Advanced image dialog",delta_height:"",delta_width:"",image_desc:"Insert/edit image"},
advlink:{advlink_desc:"Change link dialog to Advanced link dialog",delta_height:"",delta_width:"",link_desc:"Insert/edit link"},
epiaccesskeysremove:{desc:"Remove accesskey attributes for editor [EPiServer]",
epiaccesskeysremove_desc:"Remove accesskey attributes for editor [EPiServer]"},epidialogresize:{desc:"Automatic resize of dialogs [EPiServer]",
epidialogresize_desc:"Automatic resize of dialogs [EPiServer]"},epidynamiccontent:{desc:"Dynamic content",
epidynamiccontent_desc:"Dynamic content"},epieditordisable:{desc:"Enable/disable editor [EPiServer]",
epieditordisable_desc:"Enable/disable editor [EPiServer]"},
epiexternaltoolbar:{desc:"Removal of toolbar and content size dependency [EPiServer]",
epiexternaltoolbar_desc:"Removal of toolbar and content size dependency [EPiServer]"},
epifilebrowser:{desc:"Use EPiServer CMS file selection dialog [EPiServer]",
epifilebrowser_desc:"Use EPiServer CMS file selection dialog [EPiServer]"},
epifilemanagerdragdrop:{desc:"Enable drag and drop from file manager [EPiServer]",
epifilemanagerdragdrop_desc:"Enable drag and drop from file manager [EPiServer]"},
epilink:{desc:"Insert/edit link",epilink_desc:"Insert/edit link"},
epipageleavecheck:{desc:"Checks if changes have been made in the Editor when leaving page [EPiServer]",
epipageleavecheck_desc:"Checks if changes have been made in the Editor when leaving page [EPiServer]"},
epiquote:{desc:"Quote",epiquote_desc:"Quote"},
epiquote_dlg:{blockquote:"Block quote",citelabel:"Reference information about the quote",legendinformation:"Information",
legendtype:"Type of quote",quote:"Quote",remove:"Remove quote",title:"Insert quote",titlelabel:"Title",titleupdate:"Update quote"},
episearchreplace:{desc:"Search/replace modified to function with Dynamic Content [EPiServer]",
episearchreplace_desc:"Search/replace modified to function with Dynamic Content [EPiServer]"},
epivisualaid:{desc:"Enhanced visual aid [EPiServer]",epivisualaid_desc:"Enhanced visual aid [EPiServer]"},
wordcount:{desc:"Wordcount",wordcount_desc:"Wordcount"},advanced_dlg:{about_author:"Author",
about_general:"About",about_help:"Help",about_license:"License",about_loaded:"Loaded plugins",
about_plugin:"Plugin",about_plugins:"Plugins",about_title:"About TinyMCE",about_version:"Version",
anchor_name:"Anchor name",anchor_title:"Insert/edit anchor",charmap_title:"Select custom character",
code_title:"HTML Source Editor",code_wordwrap:"Word wrap",colorpicker_color:"Color:",
colorpicker_name:"Name:",colorpicker_named_tab:"Named",colorpicker_named_title:"Named colors",
colorpicker_palette_tab:"Palette",colorpicker_palette_title:"Palette colors",colorpicker_picker_tab:"Picker",
colorpicker_picker_title:"Color picker",colorpicker_title:"Select a color",image_align:"Alignment",
image_align_baseline:"Baseline",image_align_bottom:"Bottom",image_align_left:"Left",
image_align_middle:"Middle",image_align_right:"Right",image_align_textbottom:"Text bottom",
image_align_texttop:"Text top",image_align_top:"Top",image_alt:"Image description",image_border:"Border",
image_dimensions:"Dimensions",image_hspace:"Horizontal space",image_list:"Image list",
image_src:"Image URL",image_title:"Insert/edit image",image_vspace:"Vertical space",
link_is_email:"The URL you entered seems to be an email address, do you want to add the required mailto: prefix?",
link_is_external:"The URL you entered seems to external link, do you want to add the required http:// prefix?",
link_list:"Link list",link_target:"Target",link_target_blank:"Open link in a new window",link_target_same:"Open link in the same window",
link_title:"Insert/edit link",link_titlefield:"Title",link_url:"Link URL"},advhr:{advhr_desc:"Horizontal rule",delta_height:"",delta_width:""},
advhr_dlg:{noshade:"No shadow",size:"Height",width:"Width"},advimage_dlg:{align:"Alignment",align_baseline:"Baseline",
align_bottom:"Bottom",align_left:"Left",align_middle:"Middle",align_right:"Right",align_textbottom:"Text bottom",
align_texttop:"Text top",align_top:"Top",alt:"Image description",alt_image:"Alternative image",border:"Border",
classes:"Classes",constrain_proportions:"Constrain proportions",dialog_title:"Insert/edit image",
dimensions:"Dimensions",example_img:"Appearance preview image",general:"General",hspace:"Horizontal space",id:"Id",
image_list:"Image list",langcode:"Language code",langdir:"Language direction",list:"Image list",
long_desc:"Long description link",ltr:"Left to right",map:"Image map",misc:"Miscellaneous",
missing_alt:"Are you sure you want to continue without including an Image Description? Without it the image may not be accessible to some users with disabilities, or to those using a text browser, or browsing the Web with images turned off.",
mouseout:"for mouse out",mouseover:"for mouse over",preview:"Preview",rtl:"Right to left",src:"Image URL",
style:"Style",swap_image:"Swap image",tab_advanced:"Advanced",tab_appearance:"Appearance",tab_general:"General",
title:"Title",vspace:"Vertical space"},advlink_dlg:{accesskey:"Accesskey",advanced_props:"Advanced properties",
advanced_tab:"Advanced",anchor_names:"Anchors",classes:"Classes",encoding:"Target character encoding",
event_props:"Events",events_tab:"Events",general_props:"General properties",general_tab:"General",
id:"Id",is_email:"The URL you entered seems to be an email address, do you want to add the required mailto: prefix?",
langcode:"Language code",langdir:"Language direction",link_list:"Link list",list:"Link list",ltr:"Left to right",
mime:"Target MIME type",popup:"Javascript popup",popup_dependent:"Dependent (Mozilla/Firefox only)",
popup_location:"Show location bar",popup_menubar:"Show menu bar",popup_name:"Window name",
popup_opts:"Options",popup_position:"Position (X/Y)",popup_props:"Popup properties",
popup_resizable:"Make window resizable",popup_return:"Insert 'return false'",
popup_scrollbars:"Show scrollbars",popup_size:"Size",popup_statusbar:"Show status bar",
popup_tab:"Popup",popup_toolbar:"Show toolbars",popup_url:"Popup URL",
rel:"Relationship page to target",rev:"Relationship target to page",rtl:"Right to left",style:"Style",
tabindex:"Tabindex",target:"Target",target_blank:"Open in new window",target_langcode:"Target language"
,target_name:"Target name",target_parent:"Open in parent window / frame",target_same:"Open in this window / frame",
target_top:"Open in top frame (replaces all frames)",title:"Insert/edit link",titlefield:"Title",url:"Link URL"},
autosave:{unload_msg:"The changes you made will be lost if you navigate away from this page."},
common:{apply:"Apply",browse:"Browse",cancel:"Cancel",class_name:"Class",
clipboard_no_support:"Currently not supported by your browser, use keyboard shortcuts instead.",close:"Close",
edit_confirm:"Do you want to use the WYSIWYG mode for this textarea?",insert:"Insert",
invalid_data:"Error: Invalid values entered, these are marked in red.",more_colors:"More colors",not_set:"-- Not set --",
popup_blocked:"Sorry, but we have noticed that your popup-blocker has disabled a window that provides application functionality. You will need to disable popup blocking on this site in order to fully utilize this tool.",update:"Update"},contextmenu:{align:"Alignment",center:"Center",full:"Full",left:"Left",right:"Right"},
directionality:{ltr_desc:"Direction Left to Right",rtl_desc:"Direction Right to Left"},emotions:{delta_height:"",delta_width:"",
emotions_desc:"Emotions"},emotions_dlg:{cool:"Cool",cry:"Cry",desc:"Emotions",embarassed:"Embarassed",
emotions_dlg_desc:"Emotions",foot_in_mouth:"Foot in mouth",frown:"Frown",innocent:"Innocent",kiss:"Kiss",
laughing:"Laughing",money_mouth:"Money mouth",sealed:"Sealed",smile:"Smile",surprised:"Surprised",title:"Insert emotion",
tongue_out:"Tongue out",undecided:"Undecided",wink:"Wink",yell:"Yell"},fullpage:{delta_height:"",delta_width:"",
desc:"Document properties",fullpage_desc:"Document properties"},fullpage_dlg:{active_color:"Active color",
add:"Add new element",add_base:"Base element",add_comment:"Comment node",add_link:"Link element",add_meta:"Meta element",add_script:"Script element",add_style:"Style element",add_title:"Title element",advanced_props:"Advanced",advanced_tab:"Advanced",appearance_bgprops:"Background properties",appearance_linkprops:"Link colors",appearance_marginprops:"Body margins",appearance_style:"Stylesheet and style properties",appearance_tab:"Appearance",appearance_textprops:"Text properties",author:"Author",base_element:"Base element",bgcolor:"Background color",bgimage:"Background image",bottom_margin:"Bottom margin",charset:"Charset",comment_element:"Comment",content:"Content",copyright:"Copyright",defer:"Defer",doctypes:"Doctype",encoding:"Character encoding",font_face:"Font face",font_size:"Font size",fontface:"Font family",fontsize:"Font size",general_props:"General",head_elements:"Head elements",hover_color:"Hover color",href:"Href",hreflang:"Href lang",info:"Information",langcode:"Language code",langdir:"Language direction",langprops:"Language and encoding",language:"Language",left_margin:"Left margin",link_color:"Link color",link_element:"Link element",ltr:"Left to right",media:"Media",meta_description:"Description",meta_element:"Meta element",meta_index_follow:"Index and follow the links",meta_index_nofollow:"Index and don't follow the links",meta_keywords:"Keywords",meta_noindex_follow:"Do not index but follow the links",meta_noindex_nofollow:"Do not index and don\'t follow the links",meta_props:"Meta information",meta_robots:"Robots",meta_tab:"General",meta_title:"Title",movedown:"Move selected element down",moveup:"Move selected element up",name:"Name",properties:"Properties",rel:"Rel",remove:"Remove selected element",rev:"Rev",right_margin:"Right margin",rtl:"Right to left",script_element:"Script element",src:"Src",style:"Style",style_element:"Style element",stylesheet:"Stylesheet",target:"Target",text_color:"Text color",textcolor:"Color",title:"Document properties",title_element:"Title element",top_margin:"Top margin",type:"Type",value:"Value",visited_color:"Visited color",xml_pi:"XML declaration"},fullscreen:{desc:"Toggle Fullscreen Mode",fullscreen_desc:"Toggle Fullscreen Mode"},iespell:{download:"ieSpell not detected. Do you want to install it now?",iespell_desc:"Run spell checking"},insertdatetime:{date_fmt:"%Y-%m-%d",day_long:"Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday,Sunday",day_short:"Sun,Mon,Tue,Wed,Thu,Fri,Sat,Sun",insertdate_desc:"Insert date",inserttime_desc:"Insert time",months_long:"January,February,March,April,May,June,July,August,September,October,November,December",months_short:"Jan,Feb,Mar,Apr,May,Jun,Jul,Aug,Sep,Oct,Nov,Dec",time_fmt:"%H:%M:%S"},layer:{absolute_desc:"Toggle Absolute Positioning",backward_desc:"Move Backward",content:"New layer...",forward_desc:"Move Forward",insertlayer_desc:"Insert New Layer",movebackward_desc:"Move Backward",moveforward_desc:"Move Forward"},media:{delta_height:"",delta_width:"",desc:"Insert/Edit Embedded Media",edit:"Edit embedded media",media_desc:"Insert/Edit Embedded Media"},media_dlg:{advanced:"Advanced",align:"Align",align_bottom:"Bottom",align_bottom_left:"Bottom left",align_bottom_right:"Bottom right",align_center:"Center",align_left:"Left",align_right:"Right",align_top:"Top",align_top_left:"Top left",align_top_right:"Top right",autogotourl:"Auto goto URL",autohref:"AutoHREF",autostart:"Auto start",balance:"Balance",base:"Base",baseurl:"Base URL",bgcolor:"Background",cache:"Cache",captioningid:"Captioning id",center:"Center",class_name:"Class",console:"Console",constrain_proportions:"Constrain proportions",controller:"Controller",controls:"Controls",correction:"No correction",currentmarker:"Current marker",currentposition:"Current position",defaultframe:"Default frame",enabled:"Enabled",enablejavascript:"Enable JavaScript",endtime:"End time",file:"File/URL",flash_options:"Flash options",flashvars:"Flashvars",flv_autostart:"Auto start",flv_buffer:"Buffer",flv_defaultvolume:"Default volumne",flv_hiddengui:"Hidden GUI",flv_jscallback:"JS Callback",flv_loop:"Loop",flv_options:"Flash video options",flv_scalemode:"Scale mode",flv_showscalemodes:"Show scale modes",flv_smoothvideo:"Smooth video",flv_startimage:"Start image",flv_starttime:"Start time",fullscreen:"Fullscreen",general:"General",hidden:"Hidden",href:"Href",hspace:"H-Space",id:"Id",imagestatus:"Image status",invokeurls:"Invoke URLs",kioskmode:"Kiosk mode",list:"List",liveconnect:"SWLiveConnect",loop:"Loop",maintainaspect:"Maintain aspect",menu:"Show menu",mute:"Mute",name:"Name",nojava:"No java",numloop:"Num loops",play:"Auto play",playcount:"Play count",playeveryframe:"Play every frame",prefetch:"Prefetch",preview:"Preview",progress:"Progress",qt_options:"Quicktime options",qt_stream_warn:"Streamed rtsp resources should be added to the QT Src field under the advanced tab.\nYou should also add a non streamed version to the Src field..",qtsrc:"QT Src",qtsrcchokespeed:"Choke speed",quality:"Quality",rate:"Rate",rmp_options:"Real media player options",salign:"SAlign",scale:"Scale",scriptcallbacks:"Script callbacks",shockwave_options:"Shockwave options",shuffle:"Shuffle",size:"Dimensions",sound:"Sound",starttime:"Start time",stretchtofit:"Stretch to fit",swstretchhalign:"Stretch H-Align",swstretchstyle:"Stretch style",swstretchvalign:"Stretch V-Align",target:"Target",targetcache:"Target cache",title:"Insert/Edit Embedded Media",type:"Type",uimode:"UI Mode",windowlessvideo:"Windowless video",wmode:"WMode",wmp_options:"Windows media player options",volume:"Volume",vspace:"V-Space"},nonbreaking:{nonbreaking_desc:"Insert Non-breaking Space Character"},pagebreak:{desc:"Insert page break.",pagebreak_desc:"Insert page break."},paste:{paste_text_desc:"Paste as Plain Text",paste_word_desc:"Paste from Word",pastetext_desc:"Paste as Plain Text",pasteword_desc:"Paste from Word",selectall_desc:"Select All"},paste_dlg:{text_linebreaks:"Keep linebreaks",text_title:"Use CTRL+V on your keyboard to paste the text into the window.",word_title:"Use CTRL+V on your keyboard to paste the text into the window."},preview:{preview_desc:"Preview"},print:{print_desc:"Print"},save:{cancel_desc:"Cancel all changes",save_desc:"Save"},searchreplace:{delta_height:"",delta_width:"",replace_desc:"Find/Replace",search_desc:"Find"},searchreplace_dlg:{allreplaced:"All occurrences of the search string were replaced.",direction:"Direction",down:"Down",findnext:"Find next",findwhat:"Find what",mcase:"Match case",notfound:"The search has been completed. The search string could not be found.",replace:"Replace",replace_title:"Find/Replace",replaceall:"Replace all",replacewith:"Replace with",search_title:"Find",searchnext_desc:"Find again",up:"Up"},simple:{bold_desc:"Bold (Ctrl+B)",bullist_desc:"Unordered List",cleanup_desc:"Cleanup Messy Code",italic_desc:"Italic (Ctrl+I)",numlist_desc:"Ordered List",redo_desc:"Redo (Ctrl+Y)",striketrough_desc:"Strikethrough",underline_desc:"Underline (Ctrl+U)",undo_desc:"Undo (Ctrl+Z)"},spellchecker:{desc:"Toggle spellchecker",ignore_word:"Ignore word",ignore_words:"Ignore all",langs:"Languages",menu:"Spellchecker settings",no_mpell:"No misspellings found.",no_sug:"No suggestions",spellchecker_desc:"Toggle spellchecker",sug:"Suggestions",wait:"Please wait..."},style:{delta_height:"",delta_width:"",desc:"Edit CSS Style",style_desc:"Edit CSS Style",styleprops_desc:"Edit CSS Style"},style_dlg:{apply:"Apply",background_attachment:"Attachment",background_color:"Background color",background_hpos:"Horizontal position",background_image:"Background image",background_repeat:"Repeat",background_tab:"Background",background_vpos:"Vertical position",block_display:"Display",block_letterspacing:"Letter spacing",block_tab:"Block",block_text_align:"Text align",block_text_indent:"Text indent",block_vertical_alignment:"Vertical alignment",block_whitespace:"Whitespace",block_wordspacing:"Word spacing",border_tab:"Border",bottom:"Bottom",box_clear:"Clear",box_float:"Float",box_height:"Height",box_tab:"Box",box_width:"Width",bullet_image:"Bullet image",clip:"Clip",color:"Color",height:"Height",left:"Left",list_tab:"List",list_type:"Type",margin:"Margin",overflow:"Overflow",padding:"Padding",placement:"Placement",position:"Position",positioning_tab:"Positioning",positioning_type:"Type",right:"Right",same:"Same for all",style:"Style",text_blink:"blink",text_case:"Case",text_color:"Color",text_decoration:"Decoration",text_font:"Font",text_lineheight:"Line height",text_none:"none",text_overline:"overline",text_props:"Text",text_size:"Size",text_striketrough:"strikethrough",text_style:"Style",text_tab:"Text",text_underline:"underline",text_variant:"Variant",text_weight:"Weight",title:"Edit CSS Style",top:"Top",width:"Width",visibility:"Visibility",zindex:"Z-index"},table:{cell:"Cell",cell_desc:"Table Cell Properties",cell_props_desc:"Table Cell Properties",cellprops_delta_height:"",cellprops_delta_width:"",col:"Column",col_after_desc:"Insert Column After",col_before_desc:"Insert Column Before",copy_row_desc:"Copy table row",cut_row_desc:"Cut table row",del:"Delete Table",delete_col_desc:"Remove Column",delete_row_desc:"Delete Row",delete_table_desc:"Delete Table",desc:"Inserts a New Table",merge_cells_delta_height:"",merge_cells_delta_width:"",merge_cells_desc:"Merge Table Cells",paste_row_after_desc:"Paste table row after",paste_row_before_desc:"Paste table row before",props_desc:"Table Properties",row:"Row",row_after_desc:"Insert Row After",row_before_desc:"Insert Row Before",row_desc:"Table Row Properties",row_props_desc:"Table Row Properties",rowprops_delta_height:"",rowprops_delta_width:"",split_cells_desc:"Split Merged Table Cells",table_delta_height:"",table_delta_width:"",table_desc:"Inserts a New Table",tablecontrols_desc:"Inserts a New Table"},table_dlg:{advanced_props:"Advanced properties",advanced_tab:"Advanced",align:"Alignment",align_bottom:"Bottom",align_default:"Default",align_left:"Left",align_middle:"Center",align_right:"Right",align_top:"Top",bgcolor:"Background color",bgimage:"Background image",border:"Border",bordercolor:"Border color",caption:"Table caption",cell_all:"Update all cells in table",cell_cell:"Update current cell",cell_limit:"You've exceeded the maximum number of cells of {$cells}.",cell_row:"Update all cells in row",cell_title:"Table Cell Properties",cell_type:"Cell type",cellpadding:"Cellpadding",cellspacing:"Cellspacing",col_limit:"You've exceeded the maximum number of columns of {$cols}.",colgroup:"Col Group",cols:"Cols",frame:"Frame",frame_all:"all",frame_cols:"cols",frame_groups:"groups",frame_none:"none",frame_rows:"rows",general_props:"General properties",general_tab:"General",height:"Height",id:"Id",langcode:"Language code",langdir:"Language direction",ltr:"Left to right",merge_cells_title:"Merge table cells",mime:"Target MIME type",missing_scope:"Are you sure you want to continue without specifying a scope for this table header cell. Without it, it may be difficult for some users with disabilities to understand the content or data displayed of the table.",row_all:"Update all rows in table",row_even:"Update even rows in table",row_limit:"You've exceeded the maximum number of rows of {$rows}.",row_odd:"Update odd rows in table",row_row:"Update current row",row_title:"Table Row Properties",rowgroup:"Row Group",rows:"Rows",rowtype:"Row in table part",rtl:"Right to left",rules:"Rules",rules_above:"above",rules_below:"below",rules_border:"border",rules_box:"box",rules_hsides:"hsides",rules_lhs:"lhs",rules_rhs:"rhs",rules_void:"void",rules_vsides:"vsides",scope:"Scope",style:"Style",summary:"Summary",tbody:"Table Body",td:"Data",tfoot:"Table Foot",th:"Header",thead:"Table Head",title:"Insert/Modify table",valign:"Vertical alignment",width:"Width"},template:{desc:"Insert predefined template content",template_desc:"Insert predefined template content"},template_dlg:{cdate_format:"%Y-%m-%d %H:%M:%S",day_long:"Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday,Sunday",day_short:"Sun,Mon,Tue,Wed,Thu,Fri,Sat,Sun",desc:"Insert predefined template content",desc_label:"Description",label:"Template",mdate_format:"%Y-%m-%d %H:%M:%S",months_long:"January,February,March,April,May,June,July,August,September,October,November,December",months_short:"Jan,Feb,Mar,Apr,May,Jun,Jul,Aug,Sep,Oct,Nov,Dec",preview:"Preview",select:"Select a template",template_dlg_desc:"Insert predefined template content",title:"Templates",warning:"Warning: Updating a template with a different one may cause data loss."},visualchars:{desc:"Visual control characters on/off.",visualchars_desc:"Visual control characters on/off."},xhtmlxtras:{abbr_delta_height:"",abbr_delta_width:"",abbr_desc:"Abbreviation",acronym_delta_height:"",acronym_delta_width:"",acronym_desc:"Acronym",attribs_delta_height:"",attribs_delta_width:"",attribs_desc:"Insert/Edit Attributes",cite_delta_height:"",cite_delta_width:"",cite_desc:"Citation",del_delta_height:"",del_delta_width:"",del_desc:"Deletion",ins_delta_height:"",ins_delta_width:"",ins_desc:"Insertion"},xhtmlxtras_dlg:{attrib_tab:"Attributes",attribs_title:"Insert/Edit Attributes",attribute_attrib_tab:"Attributes",attribute_events_tab:"Events",attribute_label_accesskey:"AccessKey",attribute_label_cite:"Cite",attribute_label_class:"Class",attribute_label_datetime:"Date/Time",attribute_label_id:"ID",attribute_label_langcode:"Language",attribute_label_langdir:"Text Direction",attribute_label_style:"Style",attribute_label_tabindex:"TabIndex",attribute_label_title:"Title",attribute_option_ltr:"Left to right",attribute_option_rtl:"Right to left",events_tab:"Events",fieldset_attrib_tab:"Element Attributes",fieldset_events_tab:"Element Events",fieldset_general_tab:"General Settings",general_tab:"General",insert_date:"Insert current date/time",option_ltr:"Left to right",option_rtl:"Right to left",
remove:"Remove",title_abbr_element:"Abbreviation Element",title_acronym_element:"Acronym Element",title_cite_element:"Citation Element",
title_del_element:"Deletion Element",title_ins_element:"Insertion Element"}}});
Is there another way to implement spell checker on tinymce in Episerver CMS 6??
#46931
Edited, Jan 11, 2011 15:52
Hi, try following the steps here: http://world.episerver.com/Code/Magnus-Ellinge1/TinyMCE-spellchecker/
Have you configured the httphandler correctly? It's different depending on the IIS version your site is running on.
#47638
Feb 05, 2011 18:01
This has been resolved by using the internal spell checker in the browser.
I installed norwegian plugin for firefox and IESpell for Internet Explorer.
#47639
Feb 06, 2011 21:33
