I have the same error. I'm guessing there's a bug in CMS/Editor/Dialogs/DynamicContent.aspx regarding the PageReference parameters.
The problem I think is that the dynamic content edit page don't have any reference to which page you are on. Therefor the error
I think this fix it
Thanks Anders!
I needed to change the this.Page.Request["id"] == null condition to string.IsNullOrEmpty(this.Page.Request["id"]) to make it work in my case though.
When I add a Dynamic Content control to an instance of a page that isn't saved yet and the Dynamic Content controls contains a "PropertyImageUrl" I get the following error:
Note When an instance of the page exists it works fine. This only started appearing after upgrading the site from 5.2 to 6.0.
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
EPiServer.Editor.HtmlEditor.GetFileManagerBrowserUrl(PageReference id, PageReference parent, Int32 folderid) +127
EPiServer.Web.PropertyControls.PropertyUrlControl.CreateLinkEditorScript() +249
EPiServer.Web.PropertyControls.PropertyUrlControl.SetupEditControls() +811
EPiServer.Web.PropertyControls.PropertyTextBoxControlBase.CreateEditControls() +252
System.Web.UI.Control.EnsureChildControls() +145
EPiServer.Web.PropertyControls.PropertyDataControl.SetupControl() +12
EPiServer.Web.PropertyControls.PropertyUrlControl.SetupControl() +156
EPiServer.UI.WebControls.PropertyDataForm.SetupPropertyControls(Control control) +185
EPiServer.UI.WebControls.PropertyDataForm.SetupPropertyControls(Control control) +200
EPiServer.UI.WebControls.PropertyDataForm.CreateChildControls() +1489
System.Web.UI.Control.PreRenderRecursiveInternal() +60
System.Web.UI.Control.PreRenderRecursiveInternal() +223
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3393
