Change virtual path for VPP
EPiServer CMS 6, version 6.0.530.0
I have migrated an EPiServer 4 site to EPiServer CMS 5, then upgraded to CMS 6. After the migration the upload directory is declared something like this in web.config:
<add showInFileManager="true" virtualName="Upload" virtualPath="~/Upload/" bypassAccessCheck="false" indexingServiceCatalog="Web" name="Upload" type="EPiServer.Web.Hosting.VirtualPathVersioningProvider,EPiServer" physicalPath="[PATH]\VPP\Upload" />
Renaming the physical directory to "Files_sv" and changing the line in web.config to this works ok:
<add showInFileManager="true" virtualName="svenska" virtualPath="~/Upload/" bypassAccessCheck="false" indexingServiceCatalog="Web" name="Files_sv" type="EPiServer.Web.Hosting.VirtualPathVersioningProvider,EPiServer" physicalPath="[PATH]\VPP\Files_sv" />
But I also would like to change the virtual path to this "~/Files-sv/".
How can I change the virtual path for a virtual path provider the best way? SQL script or through the API?
/Hans
#42277
Aug 17, 2010 15:28
I managed to do it with SQL script
DECLARE @OldPath NVARCHAR(20) = '/upload/'
DECLARE @NewPath NVARCHAR(20) = '/Files-sv/'
UPDATE
           tblUnifiedPath
SET
           [Path] = @NewPath + SUBSTRING([Path], LEN(@OldPath) + 1, LEN([Path]) - LEN(@NewPath))
WHERE
           [Path] LIKE (@OldPath + '%')
DECLARE @OldName NVARCHAR(20) = 'upload'
DECLARE @NewName NVARCHAR(20) = 'Files-sv'
UPDATE
           tblItem
SET
           [Name] = @NewName
WHERE
           [Name] = @OldName
UPDATE
           tblRelation
SET
           [ToName] = @NewName
WHERE
           [ToName] = @OldName
I have just tested it quickly, so you better test it if you try it.
/Hans
#42314
Aug 18, 2010 15:45
