Javascript and Css files in Episerver
Hello
Can i place all the javascript and css files in file server in EPiServer CMS? If so how can i give the path for src attribute if i want to refer to file manager for Javascripts and CSS?
Rachappa
#40943
Jun 23, 2010 18:42
There are no problems store all your css and JS files in your solution. (it could a problem NOT to have css... ;-) ) Just create folders for your content, put your files in there and reference them from your code. All references are standard .Net with / beeing your site root...  You can also use ResolveUrl method in System.Web.UI.Control to get your file paths. Eg. <script type="text/javascript" src="<%=ResolveUrl("~/Scripts/js/jquery-1.3.2.min.js")%>"></script>
If your question is if it is possible to place your css and js files in the %programfiles%\EPiServer\CMS\X.X.X.X\application folders, the answer is yes, but I'm guesssing it is not a recommended solution. You can create virtual paths for a folder and share that folder between several solutions. (if you have more than one solution using the same js or css files....)
#40950
Jun 24, 2010 8:01
