Is Max Length on TemplateProperty possible?
Is there a way to specify a max length for a TemplateProperty of type "String<255"?
We would like to limit a couple properties to 80. Is there a way to do this without creating custom properties?
-Andrew
#39858
Jun 03, 2010 17:01
I can't think of one. But you don't have to create a full custom property, you can use PropertyControlClassFactory.Instance.RegisterClass to replace the control used to edit strings with the a derived class. However, in that scenario, you'll need to find a way to only limit the properties you want to be limited (and not all string properties). If you are lucky enough to be using EPiServer 6 you should be able to do this using property settings. Since you can't set the property settings for built-in properties you have to leave the default behaviour as-is, but you can add the possibility to, for instance, specify a regex for the input to be tested against.
#39868
Jun 03, 2010 20:10
