There was a problem moving an XForm definition, folder or post from the Object Store to the new Dynamic Data Store. The Additional Information panel on the Deployment Center progress window should contain more information.
Paul.
I've tried upgrading a site to CMS 6 from CMS 5 R2 SP2. When it gets to the point of upgrading the xforms it fails and I get the following error message:
Error - System.Management.Automation.CmdletInvocationException: Completed with errors - see Additional Information window ---> System.ApplicationException: Completed with errors - see Additional Information window
at EPiServer.Upgrade.CMS5.XFormUpgrader.Upgrade(String connectionString, String dbProviderName, Boolean oracle)
at EPiServer.Upgrade.CMS5.UpgradeXFormsCmdlet.ProcessRecord()
at System.Management.Automation.Cmdlet.DoProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()
at System.Management.Automation.Internal.PipelineProcessor.SynchronousExecuteEnumerate(Object input, Hashtable errorResults, Boolean enumerate)
at System.Management.Automation.Parser.PipelineNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList)
at System.Management.Automation.Parser.StatementListNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList)
What could be causing this?
