EPiServer.Configuration.Settings.Instance has not been initialized and the siteId="" has no corresponding <site> element.
has anyone else had this error and know how to get rid?!?
#41059
Jun 30, 2010 12:58
Do you have the siteid attribute in the site tag?
<episerver xmlns="http://EPiServer.Configuration.EPiServerSection">
  <sites>
    <site description="Customer" siteId="customersite.com">
#41160
Jul 02, 2010 11:23
Are you running multiple sites?  We found this happens when there's a mis-match between what site a domain name is configured in IIS and what the EPiServerFramework.config file says should be in that site.
When a request comes in, IIS maps it based on domain name.  This initializes EPiServer inside the AppDomain of that site, and sets constants like PageReference.StartPage.  If EPiServerFramework.config later says that a page from a different EPiServer site should be delivered within that same AppDomain, then you have this problem.
#41161
Jul 02, 2010 15:16
I got the same problem, for future reference check that in episerverframework.config in tag automaticSiteMapping the siteId match siteId in episerver.config
#54891
Nov 08, 2011 15:17
I had the same problem and I solved it by not using Cassini ;)
My web.config wasn't compatible with Visual Studio's IIS 6 compatible internal web server.
#62375
Oct 23, 2012 15:03
