Navigation problem - SDK
I'm trying to test the documentation from Episerver SDK 6 by using the navigation MenuList.
However Visual Studio reports a compilation error. Here is the code and then the error
    protected override void OnLoad(System.EventArgs e)
        base.OnLoad(e);
        Menu.PageLink = PageReference.StartPage;
        Menu.PageLoader.GetChildrenCallback = PageReference.StartPage;  // <== Error occurs.. EPiServer.Web.WebControls.HierarchicalPageLoader.GetChildrenMethod' is a  'type', which is not valid in the given context
        Menu.DataBind();
    /// Creates the collection for the main menu, adding the startpage
    private PageDataCollection LoadChildren(PageReference pageLink)
        PageDataCollection pages = DataFactory.Instance.GetChildren(pageLink);
        pages.Insert(0, DataFactory.Instance.GetPage(pageLink));
        return pages;
    /// Gets or sets the MenuList for this control
    public MenuList MenuList
        get { return Menu; }
        set { Menu = value; }
Kind regards,
Jon Haakon
#38692
Apr 19, 2010 10:40
I managed to make it to work by
changing the line to this:
Menu.PageLoader.GetChildrenCallback = new HierarchicalPageLoader.GetChildrenMethod(LoadChildren);
However, I don't understand "LoadChildren". The funciton is supposed to take one parameter (Pagereference),
but exception occur "method name is expeced".
Someone how have a good explanation on this?
Jon Haakon
#38693
Apr 19, 2010 11:04
Per Nergård (MVP)
It must be an error in the example. The GetChildrenCallback is a delegate expecting a method that conforms to methothname(Pagereferece).
When the pageloader code is run it will use the specified method instead of the builtin.
#38702
Apr 19, 2010 16:15
