[6.0.530.0] Exception in Migrate Data task
I tried to upgrade several demo site and everything went well during upgrade. There is one site that was at the latest version of CMS 5, as the others.
The thing is when I run Upgrade site  from the deployment center on this site I get the following error:
An unhandled error has occured:
Cannot resolve dependencies for the following module(s)
EPiServer.Cms.Shell.UI.InitializableModule
EPiServer.Web.InitializationModule
When executing
At C:\Program Files (x86)\EPiServer\CMS\6.0.530.0\Upgrade\System Scripts\Migrate Data (SqlServer).ps1:95 char:27
+     Set-EPiLongStringSettings <<<<  -DestinationDirectory $wizard.SelectedApplication.PhysicalPath
Any ideas?
#38041
Mar 26, 2010 18:06
I found the problem... some dlls were missing from my project and the migration wasn't able to load some librairies to perform the upgrade.
#38047
Mar 26, 2010 21:54
I had the same problem. I still had EPiServer 4 and 5 installations on the machine from the upgrade process. I uninstalled all EPiServer programs and re-installed just EPiServer 6, and it worked.
#42448
Aug 24, 2010 14:19
