A simple URL should work both with and without trailing slash
I havent dug around but... Why is a simple URL not matched when visitor use a trailing slash?
For example I have the page /intranet/services/mail/ and on it I've saved the simple URL value "mail". I would expect the user to be redirected to the page for both:
http://domain.com/mail
http://domain.com/mail/
The normal URL-handler gets me to the correct page for both non-simple URL:s:
http://domain.com/intranet/services/mail
http://domain.com/intranet/services/mail/
On a side note: Without trailing slash the handler should do a permanect redirect (301), I haven't checked if this is the case.
#46634
Dec 22, 2010 10:28
I looked around our bug system and found:
"#60010: Simple address should work if you append a slash at the end of the URL"
So it has been reported and accepted as a bug.
Regards
Per Gunsarfs
EPiServer Development Team
#46635
Dec 22, 2010 11:33
Great! I hope it'll be fixed in 6 R2 then.
#46641
Dec 22, 2010 14:47
If you need it sooner, the code in this blog post could be adapted pretty easily.
http://world.episerver.com/Blogs/Deane-Barker/Dates/2010/5/Redirecting-to-a-Simple-Address/
#46645
Dec 22, 2010 15:49
I'm stuck on CMS 5 R2, and need to get this working ASAP. Is there any fix around? I checked out Deanes example, but not quite sure how to use it. I compiled your code as is, and just wanted to see if it was called if I appended a trailing slash. But no go. :(
Cheers!
#50638
Edited, May 06, 2011 2:34
