Gettng build errors when using both EPiServer.dll and EPiServer.UI.dll in the same project
This thing have been bothering me for a couple of days now.
When I try to build my project I get the errormessage: "Error 106 The type or namespace name 'UI' does not exist in the namespace 'EPiServer' (are you missing an assembly reference?)" and the I loose the intellisence for EPiserver.UI. The weird thing is that if I remove either Episerver.dll or Episerver.UI.dll and then ad them again to my References I get Intellisense back and my project finds the EPiServer.UI-namespace. That is, until I try to build it again.
The only co-worker (who wrote the code) I can ask about this problem has been sick all week
#45417
Nov 05, 2010 14:56
The file is probably removed from the bin-folder when you build the project.
I usually put .dll-files in a separate folder, then reference them from that folder and makes sure that "Copy Local" is set to true for the reference.
Hope this will help. :)
#45424
Nov 05, 2010 15:07
The dll-files is located in another folder and I've tried "Copy Local" to both false and true.
#45433
Nov 05, 2010 17:46
I think the problem is that your code have a namespace or class called UI or EPiServer
#45436
Nov 05, 2010 19:45
Double check the actual xml of your .csproj file and make sure that the reference is in there.
It should be something similar to
    <Reference Include="EPiServer.UI, Version=6.0.530.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7, processorArchitecture=MSIL">
      <SpecificVersion>False</SpecificVersion>
      <HintPath>bin\EPiServer.UI.dll</HintPath>
    </Reference>
#45446
Nov 08, 2010 2:40
Hi, EPiServer.UI.dll is depended on some other assemblies, Microsoft.Web.Services3.dll and System.Web.DataVisualization.dll if memory serves me right.
Frederik
#45447
Nov 08, 2010 8:39
I still think this is a namespace issue....
#45448
Nov 08, 2010 8:40
Thanks Frederik Vig for the advice! The problem resolved utself when i installed MS Charting.
#45493
Nov 09, 2010 12:45
Microsoft Chart Controls did the trick. Install it from http://www.microsoft.com/download/en/details.aspx?id=14422
#53414
Sep 07, 2011 15:15
