New InitializationEngine not working with .NET 4.0?
I'm trying to add an initialization module to a new .NET 4.0 project, but compile fails after adding the [InitializableModule] attribute to the class, stating that:
1. The type 'System.ComponentModel.Composition.ExportAttribute' is defined in an assembly that is not referenced by EPiServer.Framework.dll
2. EPiServer.Framework.InitializableModuleAttribute is not an attribute class.
Any ideas?
#45048
Oct 27, 2010 14:13
Check the step in section 6. of this article. It should solve your problem:
http://world.episerver.com/Articles/Items/EPiServer-CMS-60-now-supporting-ASPNET-40/
#45053
Oct 27, 2010 19:00
Thanks a lot!
Of course, I had the version of System.ComponentModel.Composistion.dll that is installed with .NET 4.0 referenced, replacing this reference with the one included in the EPiServer installation solved the problem.
#45062
Oct 28, 2010 10:38
