No answer, I solved it at the moment by overriding the pageprovider. But I dont want to solve it this way. The problem is that the PageProvider requires EpiServer Enterprise. There must be another way to solve this?
public class OverridedLocalPageProvider : LocalPageProvider
public override EPiServer.Core.PageReference Copy(EPiServer.Core.PageReference pageLink, EPiServer.Core.PageReference destinationLink, bool publishOnDestination, bool allowThreading)
return base.Copy(pageLink, destinationLink, false, true);
And then added the following to episerver.config
<pageProvider>
<providers>
<add name="default"
type="Saab.EpiServer.OverridedLocalPageProvider, Saab.EpiServer"
capabilities="Create,Edit,Delete,Move,Copy,MultiLanguage,Security,Search,PageFolder" />
</providers>
</pageProvider>
If it's only done 4 times a year I would probably do a Action Window plugin where you choose source and destination and then execute the code above. Seems a bit drastic to "create" your own pageprovider for that purpose.
Another approach could be to attach an event to publishing-page, not sure how to check if you're copying a page, but I guess you can somehow.
When I copy a published node (containing many subnodes) and paste it into another node It will automatically become published, why? I need to change this behaviour, Pasted nodes should be unpublished by default.
There must be an easy way to fix this, since there are no easy way to unpublish a node including subnodes.
We have a mainnode containing 40-50 subnodes that will be copied and pasted 4 times every year.
