[Build 6.0.442.2] Exception during initialization when VPN tunnel is open
The following exception occurs (repeatedly) if EPiServer is uninitialized and a VPN connection is open. It is reproducible.
/Fredrik
Stack Trace:
[SocketException (0x2747): An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full]
System.Net.Sockets.Socket.setMulticastOption(SocketOptionName optionName, MulticastOption MR) +1558298
System.Net.Sockets.Socket.SetSocketOption(SocketOptionLevel optionLevel, SocketOptionName optionName, Object optionValue) +157
Microsoft.ServiceModel.Samples.UdpChannelListener.CreateListenSocket(IPAddress ipAddress, Int32 port) +358
Microsoft.ServiceModel.Samples.UdpChannelListener.OnOpen(TimeSpan timeout) +111
System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout) +261
System.ServiceModel.Dispatcher.ChannelDispatcher.OnOpen(TimeSpan timeout) +72
System.ServiceModel.ServiceHostBase.OnOpen(TimeSpan timeout) +107
System.ServiceModel.Channels.CommunicationObject.Open() +33
EPiServer.Events.EventsInitialization.Initialize(InitializationEngine context) +542
EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +330
EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType) +82
EPiServer.Framework.Initialization.InitializationModule.StaticInitialization(HostType hostType) +192
EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +65
EPiServer.Global..ctor() +54
EPiServer.Templates.Global..ctor() +5
ASP.global_asax..ctor() +5
System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck) +0
System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache) +86
System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache) +230
System.Activator.CreateInstance(Type type, Boolean nonPublic) +67
System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +1051
System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +111
System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +215
System.Web.HttpApplicationFactory.GetPipelineApplicationInstance(IntPtr appContext, HttpContext context) +56
System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +231
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +8897659
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +85
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +333
Version Information: Microsoft .NET Framework Version:2.0.50727.4927; ASP.NET Version:2.0.50727.4927
#35649
Dec 18, 2009 21:55
Correction 6.0.441.2
#35650
Dec 18, 2009 21:57
This has been reported as bug:
Bug #33715: Crash when starting app - "...system lacked sufficient buffer space or because a queue was full"
#35777
Dec 23, 2009 9:55
