PropertyLinkCollection doesn't work with Textarea
my pagetype has a few propertyes. One of them PropertyXhtmlString but without a toolbar it appears as textarea. As result we have errors in javascript for another property PropertyLinkCollection. When PropertyXhtmlString control appers with toolbar (realy it is iframe), we don't have such errors.
#35829
Dec 30, 2009 9:45
Hello Andrey,
I have now tried this in our latest build and in RC1 and have not been able to reproduce the issue, it have been working fine for me. If we are to continue to search for a solution we need more information.
What version of EPiServer are you using?
What browser/ what version of browser?
When you say "without toolbar" do you mean you are using PropertyLongStringControl to render the property, using the old editor in firefox or that you have used javascript to remove the toolbar or something else? More info would help on the repro of the issue.
Hopefully this is an issue that have been solved in a later build than you are using.
#36311
Jan 25, 2010 13:48
Could not reproduce the bug again. Problem was fixed by moving property on another tab. New bug was noticed: didn't save title in Link item collection sometimes. Also was fixed by moving property.
PS: our pagetype  has about 30 properties in 8-th tabs. May be we have conflict at HTML or JS tags with your one.
#36421
Jan 28, 2010 7:44
It is very hard to see what the problem is without looking at code and such in your specific setup. But its good that you where able to find a workaround. Hope that works ok for you. if you are able to find a more reliable way to reproduce the bug (know what code conflicts or know of a way we can reproduce the problem) please feel free to tell us so we can help you solve it.
#36458
Jan 29, 2010 9:27
