Unique value per langauge - Built in properties
Im pretty sure this is not possible without directly changing in the database, although is it possible to change the unique value per language option on Internal properties i.e. PageSortOrder ?
Not using PTB
Minesh
#80460
Jan 23, 2014 10:49
Hi Minesh!
I looked into this for you, but I couldn't find any easy way to do it. Had a plan of adapting the admin mode pagetype editor, but PageSortOrder is not in the PageType Definitions list, which complicates things. Let me know if you find a way, would be interesting to see it done.
//Mathias
#81226
Feb 12, 2014 9:06
