Hi Rajesh!
Could you please explain what you mean with "dragging file with same name"?
Is it files with names that already exists in the folder?
/johan
I have the same Epi7 problem. If I try to drag and drop a file with the same name as a file allready existing in the folder I get an error message. In EPi6 I got a message "Do you want to overwrite" or something like that.
When using Advance File Upload - drag and drop user gets pop-up "The file upload operation failed with error code [500]" when dragging file with same name.
Tried logging error but nothing gets added to logs.
Note: We are not using "Themes" so the solution by Jonas Lindau is not valid
http://world.episerver.com/Blogs/Jonas-Lindau/Dates/2009/10/Error-500-when-using-advanced-fileupload-drag-and-drop/
/-/Rajesh/-/
